Lighting your Prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Gabriel Perez, Sep 7, 2013.
  1. Gabriel Perez
    Gabriel Perez New Member
    Pasco, Wa.
    Is it safe to drive your Prius when there is lighting? My wife heard rumors and was a bit skeptical about driving it during a thunderstorm since it is run by batteries? All input greatly appreciated.
  2. ursle
    ursle Gas miser
    1,049
    192
    NH
    Because a car is on rubber, it's not exactly grounded, lightning will not seek it for ground
    A search will satisfy your curiosity, as no prii have yet been taken out by lightning.tmhk
  3. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Yes you want lighting. Otherwise you can't see.:D
    I think you mean lightning. That's just an old wifes tale.:D. You will be fine. The Prius is my only car. It goes rain or shine.
    SAMSUNG-SGH-I747 ? 2
  4. Gabriel Perez
    Pasco, Wa.
    Thanks so much!
  5. El Dobro
    El Dobro A Member
    7,093
    3,271
    Yea, I was wondering about that.
    OP, you may want to fix the title.
  6. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Only a moderator can change the thread title. You can report this thread to a moderator and request the change. ;)
    SCH-I535
  7. El Dobro
    El Dobro A Member
    7,093
    3,271
    The OP can click on edit in his first post, when the box pops up, he then clicks on more options. When that comes up, he can then edit the title and save the changes.
  8. fuzzy1
    10,603
    Cars do get hit by lightning. If that big spark can jump through 10,000 feet of air above, it can also jump 5 inches below. An area motorcyclist is recovering after being struck by lightning on I-5 near Chehalis just two days ago.
    Motorcyclist hit by lightning in stormy end-of-week weather | Local News | The Seattle Times
    Car passengers are generally safe, as the lightning follows the metal frame. Motorcyclists are not so protected, the guy above lost some hair melted to the inside of his helmet.
    You didn't search very hard, here is one: 08 Prius struck by Lightning! Passengers unhurt, some electronics destroyed. The OP is the repair guy, and has some insight into what gets damaged in other struck cars as well as the Prius.
