Lights Come on But engine doesn’t start
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Michael Salazar, Aug 18, 2022.
  1. Michael Salazar
    Michael Salazar New Member
    Corbin
    When I push the start button, the dashboard lights come on, but the engine does not. After a couple attempts and minutes later, the engine will come on with no problem.
  2. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    engine will come on when it needs to
  3. Tombukt2
    Tombukt2 Senior Member
    13,792
    2,498
    Durham NC
  4. Tombukt2
    13,792
    2,498
    Durham NC
    When you say you have all the lights on but the engine doesn't start are you asking the engine and car to do anything like backup go forward?. Is the car ready green ready if so the car is ready you need to put it in gear and get your rear end on the move of course the lights are on they should also go off after a second what do you mean the lights are on Not supposed to stay on like I say back the car up put it in forward and go 3040 ft those light should all be out or you have codes set and it's time to read them.
  5. bisco
    52,752
    make sure the brake lights come on when you press the pedal
    check the 12v health
  6. ASRDogman
    ASRDogman Senior Member
    8,019
    4,072
    Sounds normal. Depending on the % of charge of the hybrid battery.
    If you put it in gear, and start to drive, does it come on? Have you driven the car?
