Lights on = lower mpg?
Discussion in 'Gen 3 Prius Fuel Economy' started by DBaum, Jan 23, 2010.
  1. Texas911
    Texas911 Member
    405
    Houston, Texas USA
    How visible is white in snow?
  2. Texas911
    Texas911 Member
    405
    Houston, Texas USA
    Well in this logic, why bother turning lights on in the dark or having brake lights at all? Or turn signals? All cars have brake lights, by that logic, we're all "used" to it. And we ignore them. Look at the bigger picture.
  3. hockeydad
    hockeydad New Member
    298
    23
    zip
    You're kidding, right? ;) I don't drive in white-out conditions, otherwise, the roads are usually plowed where I live, and are black/dark grey. Are your roads white where you live? :rolleyes: For those that do venture out in such bad weather conditions, they usually do so at significantly reduced speed, and the roads are free of much of the traffic. Around here, as soon as we have 1 flake of snow, it becomes grdilock as people drop to a crawl. The risk that they face is loss of traction...and not being seen by other drivers. :cool:
  4. hockeydad
    298
    23
    zip
    That might be YOUR logic, but MY logic says - you turn your lights on when it's dark outside, to see the road, and to see what's next to the road. LOL. :D Brake lights are there to alert the guy behind you that you are braking. As far as turn signals - most around here don't use them.
    Your "logic", if that's what you want to call it, is flawed. :eek: The 3rd light on the car had drammatic changes (when first introduced) in reducing rear-end collisions. Look it up. However, in time, the rear-end collision rate returned to what it was prior to the insertion of the 3rd light. People adapt, and so do their brains.
  5. Texas911
    Texas911 Member
    405
    Houston, Texas USA
    I can see that all your posts only concern your point of view. I guess that's your right. But to others, please turn on your lights so other people can see you out there. Its not about you being able to see others, quite the contrary, its so that others can see you.
  6. hockeydad
    298
    23
    zip
    Ditto. You either ignore, or fail to grasp what others have written, and what studies have shown. Your position is not supported by the facts. That said, I'm not a complete convert to the no light...that's why I do turn on my parking lamps in many situations, such as cloudy days.
    But here's my point - Unlike you, I'm not telling anyone what to do.
    Oh, and while we're on the subject of safety - get a light colored car. ;) If you're going to preach what we should do, then you might want to go all the way.
  7. hockeydad
    298
    23
    zip
    Oh, and it's far more important to this group of motorists, so a number of compehensive studies have been done: An evaluation of the effectiveness of motor cycle daytime headlight laws. -- Muller 72 (10): 1136 -- American Journal of Public Health
    A Muller
    Currently, 17 states mandate the daytime use of motorcycle headlights. The purpose of these laws is to make the motorcyclists more conspicuous and reduce the number of daytime multi-vehicle collisions. The effectiveness of the laws is examined by comparing the proportion of daytime fatal, front, and side-angle collisions between states with and without such laws. The comparison is based on all motorcycle fatalities recorded by NHTSA for the years 1975-80. The analysis shows no statistically significant difference between states with and without such laws, suggesting that daytime headlight laws are ineffective. Several explanations of this negative finding are explored.
    Further -
    "A 2008 study by the U.S. National Highway Traffic Safety Administration analysed the effect of DRLs on frontal and side-on crashes between two vehicles and on vehicle collisions with pedestrians, cyclists, and motorcyclists. The analysis determined that DRLs offer no statistically-significant reduction in the frequency or severity of the collisions studied, except for a reduction in light trucks' and vans' involvement in two-vehicle crashes by a statistically-significant 5.7%.[5]
    Effect of ambient light
    The Daytime Running Light was first mandated, and safety benefits first perceived, in Scandinavian countries where it is frequently and persistently dark during daytime hours in winter time. As ambient light levels increase, the potential safety benefit decreases while the DRL intensity required for a safety improvement increases {can you say high beams?}. The safety benefit produced by DRLs in relatively dark Nordic countries is roughly triple the benefit observed in relatively bright Israel and America.[2]
  8. orange4boy
    orange4boy Member
    231
    44
    Vancouver BC
    2003 Prius
    The wattage of the bulbs does not tell the whole story. You have to factor in the losses of converting from engine power to HV into battery, out of battery through DC-DC converter and then the losses through the wiring to get the real numbers.
    In a regular ICE the figure can be easily doubled to get the actual power required by the engine. Darin (AKA MetroMPG) at ecomodder tested his Geo Metro and got a 10% improvement in mileage from running without an alternator.
    I suspect you could see similar numbers with a Prius. Power consumption is higher than a Metro.
    The headlights are the least of your problems.
  9. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    A Muller
    Any motorcyclists out there? None that I have bought in the last 20 years or so have had the capability of turning the headlight off.
    I believe that might just invalidate the above assertion.
    Common sense, your more visable with the headlights on, even more so if they flash, worried about the guy behind you? Mod your brake lights so they flash.
    Want to save gas? Cut down on driving, buy a bicycle, car pool, combine trips etc., but when you drive, leave the lights on.
  10. orange4boy
    orange4boy Member
    231
    44
    Vancouver BC
    2003 Prius
    What I have noticed out there are motorcycles with flashing headlights. That really got my attention.
    Is that a new product at work or a fautly generator?
  11. hockeydad
    298
    23
    zip
    Really? How is that? Just because the Government mandates something, does not mean it's right, or based on the findings of numerous studies? Most "safety related mandates" we have today are put in place because a fear of litigation. It only takes one case to bring on yet a new mandate. I guess the argument can always be made that if it save just one life, it's worth having the law.
    That said, if it's a proven fact that it helps, why aren't DTL mandatory on cars? Why don't we have them on the 2010 Prius? More people are killed by drunk drivers...why don't all cars have a breath-alyzer lock-out so you can't drive over a certain limit? I guess just a matter of time until we've incorporate every possible "safety feature" to protect all, from the irresponsible few.
    But things have gotten out of control, IMO. Ever been to a public pool lately? Back when I was growing up, every pool had diving boards - low and high. Not so much anymore. Is this a real safety issue for most people that go to the pool?? Or yet another over-reaction to a few that have hurt themselves on a diving board, and pools not wanting to face litigation?
  12. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    If the lights were consuming so much to affect by 2 or more mpgs, then Toyota would have adopted a more fuel efficient way to feed the lights (i.e. LEDs for all versions, or high efficiency lights for daylight - position lights, etc).
    Since the lamps are what they are (standard halogen ones) - this means that the fuel consumption is likely minimally impacted by turning on the lights. I think A/C, heater and driving style play a much bigger role in FE.
    The difference with a normal car though, is that in the Prius each thing that is turned off can leave more energy to the HV voltage battery that can provide electricity for more distance travelled or support the engine more often. Any portion of that going into a utility (e.g. radio) will reduce the HV charge and hence affect somehow the FE, likely visibly - depending on the length of a trip, averaging 0L/100km for 500m more, might mean a quite different consumption average. This is my experience on the 17km commute I do every day.
    In normal cars, no matter what you do, the engine runs all the time. More utilities will increase the load on the alternator that needs to draw more current to keep the 12V battery charged while providing current to the utilities. You turn everything off, the engine still has to drag the alternator, the AC (even when not running and disconnected via the magnetic clutch), etc. We know, in comparison, how the ICE design of the Prius is optmised for avoiding continuous loads when not used (electric pumps and so on). So, if a normal engine is not burdened by several electric loads, there is in any case not much it can do with the portion of energy it could not waste (no HV battery to charge...).
  13. orange4boy
    orange4boy Member
    231
    44
    Vancouver BC
    2003 Prius
    It would be great if someone would do a good controlled test to see the mileage difference in the Prius with all accessories off and then with a bunch on.
    Then you could calculate the losses as they relate to mpg.
    The graham scanner reports the HV battey is supplying 1.5 to 2.5 amps of ~270 Volts to the DC-DC converter to run the basic requirements. that's .54 to .9 horsepower before calculating in the generator and battery losses, which means that the engine has to come up with a bit more than that accumulated power somewhere in the driving cycle. Since that draw is constant during ready mode, that's quite a few of watts all told.
    I'd be thrilled to take a horsepower or two of load off the engine.
  14. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    No need to test. It's very easy to calculate based on a given load. There are a few posts explaining this calculation.
    Tom
  15. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    The extra load of the headlights depends on how fast you're going, but it's typically not that much. A quick comparison of power usage:
    Headlights: each headlamp is rated at 55W, each tail lamp at 10W (Gen 2, halogens). Total 130W.
    Power required to balance aerodynamic drag at 70mph: 12,000W, plus any other sources of friction and tyre rolling resistance.
    Drag at 30mph is about 990W. At 20mph, about 290W. At these speeds rolling losses are dominating. I don't have figures from the Prius but I can point you to Tesla's range information. If you multiply watt·hours per mile by miles per hour, you get watts. If you do this for the tyres you get a figure of 1,622W at 30mph and 1,058W at 20mph. The Prius has a base electronics load of about 300-400W.
    Headlamp load is therefore fairly significant at lower speeds, but is not likely to have a massive impact on fuel economy.
  16. orange4boy
    orange4boy Member
    231
    44
    Vancouver BC
    2003 Prius
    Good post Mike.
    2 things to add.
    1) Your headlights are presumably on at all times, even when stopped so that has a cumulative effect.
    2) The total watts required is higher because of efficiency losses. 13.8V/DC-DC/HV battery in-out/generator/engine. I have roughly figured the system to be about 65 to 70% efficient. So the engine needs to supply about 190 watts to get 130 at the bulbs.
  17. qbee42
    18,058
    3,079
    Northern Michigan
    I think what Mike really means is that the headlight load stays constant while the power required to move the car varies with speed. Because of that, the mileage reduction due to headlights varies with speed.
    Tom
  18. orange4boy
    orange4boy Member
    231
    44
    Vancouver BC
    2003 Prius
    Did the numbers as per mikes post and headlights eat about ~1% at 70mph ~5% at 30mph Very rough figures.
  19. briank101
    briank101 Member
    170
    68
    Western Chicagoland
    So based on the last post, as my car's average speed is usually about 25 mph, this may be about a 6% to 7% hit to my mpg when lights on. By logical extension, those with a 20 mph avg speed or lower (typical of all city driving) may be taking an 8 to 10% or more hit on mpg. A pair of low beam halogens costing $25 with 1000 hr life, which is 25,000 miles at 25mph, so assuming 50 mpg which is 500 gallons of fuel used, the bulb replacement costs are like adding 5 cents per gallon. So if one can design/install some kind of LED DRL system that flashes for 1/8 of a second every second (that will effectively use 96% less electrical power), an an already efficient city driver (avg 20 mph) may realize an additional 8% savings in fuel versus the standard headlights on, no small amount in the Prius mpg world.
  20. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    hard to believe headlights provide that much of a hit on your mileage. In my LEAF, I cant really see a difference but the duration times on would be lower and LEDs have smaller footprint
