Limit charging to 95%???
Discussion in 'Gen 5 Prime Charging' started by Ashevillian, Feb 28, 2024.
  1. Ashevillian
    Ashevillian Junior Member
    Asheville, NC
    2024 Prius Prime
    XSE
    Hi All,
    I'm new here, although I have been following these forums for the last few months. I ordered a new, 2024 XSE and it was delivered a few weeks ago. One issue I have is the engine wants to auto-start in EV mode when full charged.
    Let me explain. I live up the side of a hill. The first 3/4 of a mile, the altitude drops 700 feet. Then its a long slow decent of a couple hundred feet over the next 2 miles. About 2/3 the way down the first decent, the engine starts. It stays on for the next couple of miles, and then turns off when I actually start using energy from the battery.
    If its not fully charged it does not do this. I assume this is something to keep from overcharging the battery, I get it. So is there a way, besides manually tracking it and stopping the charging before complete?
    Thanks!
    Ashevillian
  2. vvillovv
    vvillovv Senior Member
    4,336
    1,518
    NY
    Gen 4 Prime behaved that way too. I know there isn't a way to stop the charge automatically below the full charge level for the Gen 4 (at least that I've ever seen or head about. I suspect Gen 5 is similar, only because your post is the first of the Gen 5 Primes to get a post about it. but I'd love to hear someone find a way to stop the charge at 90 or 95% SOC.
    With a downhill like you describe above you should be able to figure out at what SOC you need to stop the charge to get to the bottom with 100% SOC and no engine startup. Though in the summer you'll probably have to stop the charge earlier.
  3. NullDev
    NullDev Member
    121
    63
    Ohio
    2024 Prius Prime
    XSE
    Depending upon your technical ability, you can use "smart home" automation to this. In my case, I use Home Assistant and a smart plug which monitors watt-hours. I can configure the plug to shut off after a certain number of watt-hours has elapsed which is fairly accurate assuming you tend to start with a empty battery. Obviously, this isn't as handy as being able to set a "max charge %" in the car's menu, but it does work.
    PrimeDan, douglasjre and vvillovv like this.
  4. Downrange
    Downrange Active Member
    373
    214
    2024 Prius Prime
    SE
    Remember full charge is only around 80% charge, IIRC, just as "empty" is 20% full. I just don't worry about it and let the battery mgmt. sys. do its thang.
  5. vvillovv
    4,336
    1,518
    NY
    Any device suggestions? Can the smart plugs and app connect without any other equipment needed?
    If other equipment is needed to get the monitoring functionality to work, what would be a minimal setup, either device(s) or cost wise?
  6. Ashevillian
    Asheville, NC
    2024 Prius Prime
    XSE
    Hi Downrange,
    I understand that "fully Charged" is really actually 80% SOC. I am trying to prevent the engine from starting up, and basically idling for 5 minutes before shutting off. I can't believe that is very good for the engine, and it wastes gas.
    Downrange and vvillovv like this.
  7. NullDev
    NullDev Member
    121
    63
    Ohio
    2024 Prius Prime
    XSE
    The process is not for the faint of heart, but can make for a fun project if you like to tinker.
    I use a Sonoff S31 smart plug which can also measure energy usage. I then flashed Tasmota to the S31 following this procedure. Once that is done, you need to install and configure Home Assistant. There are lots of devices that you can install this to, but probably the least expensive is a Raspberry Pi. Then, you link Tasmota running on your S31 switch to Home Assistant. This will let you monitor the energy usage and do actions based on it.
    douglasjre likes this.
  8. vvillovv
    4,336
    1,518
    NY
    Thanks for the links and warning ;). I watched the Tasmota flashing videos and sussed out some more info about hubs and devices at amazon. Looks to me that to keep the home systems out of the cloud based services, it takes a bit of extra work. Keeping the smart devices on the local network is nice for added privacy since no one knows what's actually going on in the vendor cloud except maybe the vendor ( depending on which one's being used ).
    I also read some descriptions in the Home Assistant forums about shelly z-wave and zigbee devices
    Thought that maybe this Sonoff - Zigbee wifi gateway might work, until I remembered the ckiud and the real reason for flashing Tasmota.
    SONOFF Zigbee 3.0 USB Dongle Plus-E - SONOFF Official
    I've already got enough wifi devices, and should probably start administering them better than I have been instead of simply turning the unused ones on when they're needed occasionally.
  9. NullDev
    NullDev Member
    121
    63
    Ohio
    2024 Prius Prime
    XSE
    Yes, that's why I put Tasmota on because that keeps everything local. As you say, it's a few more hoops, but I'd prefer to be the sole reason for my network outages. I haven't gotten into Zigbee yet as everything I use is currently WiFi.
    vvillovv likes this.
  10. Edison
    Edison Junior Member
    36
    Belgrade, Maine
    2024 Prius Prime
    SE
    Ashevillian is right that running the engine for five minutes is bad for it. ICEs wear most in the first few seconds on a cold start, before lubrication has come up to pressure and begun to fully flow. While they are running cold (and rich), they blow lots of unburned hydrocarbons into their oil, which would normally evaporate out when the oil got hot enough. Instead, if the engine does not warm up, it will stay there and corrode the engine from the inside. The same types of unburned hydrocarbons condense in the cold exhaust system and do the same kind of mischief there as well. Any mechanical engineer will tell you that if you start an ICE, you should run it until it's fully warmed up. In a non-hybrid vehicle, that takes about 10 miles. It will be further with a hybrid.
  11. Dany Dan
    Dany Dan Member
    57
    38
    Québec, Canada
    2024 Prius Prime
    SE
    It is bad to always stop the load at 95%, you have to go up regularly 100% to rebalance the high voltage battery cells.
    If it's a small hill, you have to be 80% and less so that the heat engine does not start. (If it is hot)
    And if the hill is the least large, put the vehicle on the neutral and brake mechanically so that the thermal engine does not start.
  12. mva
    mva Active Member
    174
    102
    B.C. Canada
    2024 Prius Prime
    SE
    I’ve thought about this too. I live on a hill but it’s not too extreme so I can usually get down without the engine starting. I wish that Toyota gave us the option to control the amount of charge.
    If you’re consistently using the entire battery capacity then you could use the car’s scheduler to stop the charge early. For example charge for 4 hours when a full charge takes 4 1/2.
    The other advice, to put the car in neutral and use the brakes does work and keeps the brake discs from rusting.
  13. pasta4breakfast
    131
    67
    Anaheim, CA
    2020 Prius Prime
    not sure about this generation, but the previous generation had a charge schedule feature. If you leave your home around the same time each day, you can set the charge schedule to finish charging at a time that is a little later than your actual departure. You will have to play around with the schedule to get it at exactly 95% or close. That way you will get it a little below 100% charged to allow the regen down your hill. However, I don’t think you would need to worry about it not charging 100% because some days you will likely leave a little later and you will charge it to 100% by accident.
    BiomedO1 likes this.
  14. BiomedO1
    BiomedO1 Senior Member
    4,537
    2,389
    Left Coast
    Yep; use the scheduler function and set it to finish charging a half hour or forty-five minutes after your leaving. The traction pack should be almost full when you unplug. These estimates are for an L1 charger, L2 you can cut the timing in half.
    MAX2 likes this.
  15. mva
    mva Active Member
    174
    102
    B.C. Canada
    2024 Prius Prime
    SE
    I recently discovered that if I precondition the car, for 20 minutes, using the Toyota app, the engine doesn’t start up going down the hill leaving my house.
    I am also careful to be gentle with the brake pedal.
    It seems to me that the traction battery has very limited ability to accept any regen charge when it’s fully charged and cold. Push a little too hard on the brakes going down hill and the engine starts.
  16. BiomedO1
    4,537
    2,389
    Left Coast
    Yes, preconditioning is driven by the traction battery; even when it's plugged-in. Why not draw power from the plug? Japan is 100VAC, USA is 120VAC, most others are 220VAC; simpler and no additional hardware or logic programming to draw off of the traction battery.
    I recall discussions from years ago; if you precondition your car - you can start your day at less than 100% charge. The heater or AC would draw down the traction battery, You can leave the car plugged-in to let it get back to 100% but then the car would be too hot or cold again.:(
  17. Trollbait
    12,809
    Depends on the EVSE level. HVAC is a big draw, so with Level 1, the car alternates between charging and preconditioning. Level 2 is more capable of doing both at once. The gen1 Volt didn't even allow preconditioning with Level 1.
