linear valve
Discussion in 'Gen 2 Prius Main Forum' started by tallman, Apr 17, 2023.
  1. tallman
    tallman Junior Member
    60
    wv
    Can u use a snap on ultra scanner to relearn linear valve?
  2. ChapmanF
    19,086
    I believe there is even a no-scan-tool procedure for that, using a jumper wire.
    I don't know exactly which scan tools do or don't have that, but some are reviewed with those details in mind in this thread:
    Gen2 OBD2 app review | PriusChat
    SFO likes this.
  3. mr_guy_mann
    mr_guy_mann Senior Member
    4,120
    2,019
    NJ-USA
    SFO likes this.
  4. tallman
    60
    wv
    It's a ultra, I try to relearn and I get code 1368 linear valve offset fault,,, is this a bad actuator?
    Edit: Yes ultra still get c1345 and c 1368 code
    I will add though the ultra says parking brake must be set to do the c 1345 relearn and techstream says p brake must be off , I did it by just moving the pedal enough to open switch, shoes not moving
    #4 tallman, Apr 27, 2023
  5. dolj
    dolj Senior Member
    8,657
    4,408
    Wellington, New Zealand
    What is the procedure for troubleshooting those codes in the repair manual?
  6. Mendel Leisk
    42,386
    I "think" I've got it all. First page is the procedure, subsequent pages pertain to the references on first page. If there's something missing let me know.
