List of hacks and easter eggs
Discussion in 'Knowledge Base Articles Discussion' started by tag, Dec 4, 2005.
  1. tag
    tag Senior Member
    2,526
    Chicago
    Reminder Light Reset
    • Power on car, Cycle ODO/TRIP, stopping on ODO, Power off car.
    • Power on, while holding the ODO button
    o Wait for reminder light to go out, then release ODO button.
    Disabling Reverse Beep
    • Power on the car, Cycle ODO/TRIP, stopping on ODO, Power off the car.
    • Power on, within 6 seconds, hold ODO for at least 10 seconds.
    • While still holding ODO shift into Reverse and back into Park.
    • b-on shows on speedometer display, press ODO to cycle to "b-off".
    • This also works for the seatbelt beep, replace shifting with buckling/un-buckling.
    Tachometer Signal
    Found it at vfaq.net (http://www.vfaq.net) which has an image in the mods-Buttons/Guages section, 04_TachECM.gif (http://www.vfaq.net/pics/04_TachECM.gif) contributed by Wayne Brown, which shows pin5 to be a tach signal wire which should drive a standard tachometer.
    Touch screen diags, for 2004 or newer
    Use of this information might result in disabling your vehicle, use it at your own risk.
    • Hold Info button while turning the lights on and off 3 times, you can wait for system checks. -OR-
    Press the display button, then press the left upper and lower corners within the display settings box 3 times.
    o If codes exist press LAN Mon, then CHEK to show codes or hold code clr to clear codes.
    • From the initial screen, hold Info button while turning the lights on and off 3 times
    for Model Info Set Up (type) screen. I do not know what these do, use at your own risk.
    o Types are : 690N 740N 836N 783N 620N 808N 480X 900N 382X 290X
    Types are : 901N EMV AVX(ten) AVX(nat) AVX_HV(ten) AVX_HV(nat) 749N
    • Use the Menu button to reach the Diagnosis Menu, press the Display Check and then
    Vehicle Signal Check to show the accessory battery voltage and other information.
    • From the Diagnosis Menu press upper-left then lower-right screen corners for PDM menu.
    o All buttons except for perhaps the Init. BackUp may be safe to use.
    • From PDM screen, hold Info button while turning the lights on and off 3 times for an untitled screen.
    o Here you find a number of options stating success or PGM rqd including TKM, Flicker,
    setting:Tape/MD, setting Address:110H/120H, setting AC:eek:ff/on, and setting Auto:eek:ff/on
    • Hold the physical Display button to exit at any time, or simply power off the car.
    Disabling Traction Control
    WARNING: The shop manual apparently states in no uncertain terms that this procedure must NOT be used to drive the car as damage to the transmission could occur due to traction control being defeated.
    • Follow the sequence below (quickly - within 60 seconds)
    • Set Ign switch to ON, not READY (Power button twice, no brake)
    • While still in "P" fully depress the gas pedal two times.
    • Select "N" fully depress the gas pedal two times.
    • Select "P" fully depress the gas pedal two times.
    (LCD display will indicate a !Car! in upper left corner of screen)
    • Turn key directly to "start" to start the engine (brake+start button)
    It forces the ICE to run continuosly and defeats the traction control system. Normal operation returns after turn off and reboot. Unlike EV-Mode this is strictly a diagnostic function and should not be used under normal situations.
    Disabling Navigation Lock-Out
    When moving faster than a very slow speed, many of the navigation setting buttons are disabled (grayed-out). This sequence will override the lock-out until the car is powered off.
    • Press the "Menu" button (hardware button)
    • Press the "Voice" icon on the display
    • Press the upper left corner of the display, where the speaker icon is
    • Press the lower left corner
    • Press the upper left corner again
    • Press the lower left corner again
    • The screen should change to a diagnostic screen
    • Hold the "Override" button for several seconds until it changes to black
    Warning: do not play with things on this screen that you don't know about!
    "Programming New Keys"
    STEPS:
    1. Begin by sitting in the driver seat with all the doors shut.
    2. Insert your working master (black) key in the ignition.
    3. Very Quickly, turn the key from "LOCK" to "ON" 5 times. (You will end with the key in the "LOCK" position)
    4. Immediately, open and close the driver door 6 times very quickly. (End with the door closed)
    5. Immediately, remove your working Master Key and insert your new Master Key
    6. Turn the key to the "ON" position and leave it there while you wait for 1 minute.
    7. After the minute, if you want to program another key, just remove the first one and insert the next one, turning it to "ON" and leaving it in position for 1 minute.
    8. When you are through programming keys, just take the last one out, open and then close the driver door to lock in the programming, and your done smile.gif
    Programming Sub Keys (Grey) is done the same way except you turn the master key 4 times before you open and close the door 5 times. Then insert the sub key, turn to the "ON" position, and wait your minute. Finish by removing the key and opening and closing the door 1 time as before.
    You can erase all the keys and start over by turning a working master key 6 times and then opening and closing the door 7 times. Then remove the key and reprogram again.
    Remember : You only have a few seconds to perform each maneuver so don't waste time. You will know when you have done it right when you insert the blank key and the security light on the radio stops blinking. If it does not work, try completing the sequence faster, time yourself. And don't worry, if it doesn't work the first time, just do it again smile.gif
    **It is our understanding, according to the book, you can have 2 master keys and 1 sub key, however, we are aware of one gentleman who was able to program 4 masters and 2 subs. We currently have 3 masters and 1 sub.**
    Adding Extra Remote Transmitters or Replacing a lost or damaged one
    Following is an explanation and the procedures for each of the possible programming functions. The Prius is capable of responding to a total of 4 remotes. If you attempt to program more than 4, it will erase the first remote programmed to make room for the next.
    There are four different programming commands when setting up or verifying your remote transmitter, they are:
    A. Add mode, used to add a remote to your Prius that is not currently registered.
    B. Rewrite mode, used to erase all previously registered remotes and allow you to begin again the programming process.
    C. Confirmation mode, used to verify the number of remotes that are already programmed in your Prius.
    D. Prohibit mode, to prohibit all remotes from operating the door locks.
    All four modes start with these instructions:
    1) Make sure that the key is not in the ignition, the doors are unlocked, and the driver's door is open.
    2) Very quickly, without turning, insert and remove key from the ignition twice. (leave key out)
    3) Close and open the driver door twice. (leave door in open position)
    4) Again, insert key into the ignition and remove it. This time only once. (leave key out)
    5) Close and open the driver door twice, then close the door.
    6) Insert key into the ignition and leave it in the LOCK position.
    A. Add mode:
    A1) Turn the key to "ON" for 1 second, then turn back to "LOCK".
    A2) Remove the key.
    A3) You’ll hear the doors "LOCK" and 1 second later "UNLOCK" (just listen)
    A4) On your remote, press the lock and unlock buttons simultaneously for 1 to 1½ seconds, then let go.
    A5) On your remote, IMMEDIATELY press unlock by itself.
    A6) You’ll get one of three responses:
    R1) You’ll hear the doors "LOCK", then "UNLOCK" once. The remote is accepted. If you want to program another remote, immediately proceed to step A4 with your second remote, otherwise open the driver’s door and the remote is registered.
    R2) You’ll hear the doors "LOCK", then "UNLOCK" twice. Either you didn’t use the same remote in steps A4 and A5(not likely), or this remote was already registered.
    The timing was off when you pressed the LOCK and UNLOCK buttons simultaneously and then UNLOCK by itself. Immediately press the two buttons together and the unlock by itself again. Keep trying until you get the locks to signal once that you have been successful. Then if you have another remote to program, quickly press its' buttons as before, until you hear the locks signal once. When you are finished, open and close the driver door to lock in the programming.
    R3) If no response, go back to step 1 near the beginning of these instructions.
    B. Rewrite mode:
    B1) Turn the key to "ON" for 1 second, turn back to "LOCK" for 1 second, then back to "ON" for 1 second, and finally back to "LOCK" for 1 second
    B2) Remove the key.
    B3) You’ll hear the doors "LOCK", 1 second later "UNLOCK", 1 sec., "LOCK", 1 sec. "UNLOCK". (just listen)
    B4) On your remote, press the lock and unlock buttons simultaneously for 1 to 1½ seconds, then let go.
    B5) On your remote, IMMEDIATELY press unlock by itself.
    B6) You’ll get one of three responses:
    R1) You’ll hear the doors "LOCK", then "UNLOCK" once. The remote is accepted. If you want to program another remote, immediately proceed to step B4, otherwise open the driver’s door and the remote is registered.
    R2) You’ll hear the doors "LOCK", then "UNLOCK" twice. You didn’t use the same remote in steps B4 and B5(not likely).
    C. Confirmation mode:
    C1) Turn the key in 1 to "ON" and back to "LOCK" in one second intervals for a total of 3 times.
    C2) Remove the key.
    C3) You’ll hear the doors "LOCK" and "UNLOCK" in 2 second intervals. (just listen and count each set)
    1 Set = You have 1 remote registered
    2 Sets = You have 2 remotes registered
    3 Sets = You have 3 remotes registered
    4 Sets = You have 4 remotes registered
    5 Sets = You do NOT have any remotes registered
    D. Prohibit mode:
    D1) Turn the key to "ON" and back to "LOCK" in one second intervals a total of 5 times.
    D2) Remove the key.
    D3) You’ll hear the doors "LOCK", 1 second later "UNLOCK" 5 times. (just listen and count each set)
    D4) This will erase all previously registered remotes and cancel the wireless door lock function.
    Originally compiled by Brent
    Kthi, olerox, andyprius and 3 others like this.
  2. DanMan32
    DanMan32 Senior Member
    3,799
    26
    Tampa Bay, FL
    The key instructions are only for the classic. There are some functions on the HSD that can be done through a dance, but not many. At least the repair manual is unclear. Best to use the THHT even if dances are possible. There is no sub key with HSD.
    As for tach, IGF is the ignitor common. If the engine is not given spark, this won't prove ICE is spinning or not. Also IGF is sent for all plugs, not just one, so the output would be 4x the RPM. One would probably be better using the crankshaft position sensor, NE+ at pin 33, as long as the signal is not too high of an impedance.
    Looking at the diagnostic manual, the crankshaft sensor puts out 34 pulses per revolution so that wouldn't be good for tach, though it would be good for ICE spin detection.
  3. QAqiTsyuxzd
    QAqiTsyuxzd Junior Member
    Along with this I wonder if anyone knows a hack for the 2006 Prius FM radio to change the frequency channel separation.
    I have a US model and am presently working in Germany. The American FM radio frequencies use a .2 MHZ separation but here in Europe it's .1 Mhz. I miss alot of radio channels because I can't tune them in.
    So, is there anyway to reprogram the radio to tune at .1 Mhz steps rather than .2???
    Tks.
    Live to Drive and just smile at Hummer owners .....
    Floyd
  4. D0li0
    D0li0 New Member
    118
    Seattle, Wa
    I just wanted to mention the following editable wiki page which is similar to this Knowledge Base article. Some of the information appears to have been coppied directly from that page, which is fine, and that page links back here to this and other similar web addresses. It also includes links to the first known public mentions of many of these tricks. Anyway, feel free to "syncronize" the information at that page with others arround the web and link to and from them as you see fit. http://www.eaa-phev.org/wiki/Prius_Modifications
    L8r
    Ryan
  5. MathisTX02
    MathisTX02 New Member
    2002 Prius
    I lost my hearing in my left ear. Changing the balance setting is not what I need to hear the radio well. I have a 2002 Prius with OEM radio. I need to make it permanently MONO on FM. Anyone know an easter egg for that purpose?
  6. carbon6
    carbon6 Junior Member
    Beaveron, OR
    I've got the 2009 Prius, Touring package, w/ Nav. The sequence shown below won't work to unlock the nav while moving. When I press the menu button, I don't get a "voice icon." There is a "volume icon," but the rest of the sequence does not land me in the "Override" menu.
    Did Toyota change the software to prevent the hack? Do I have to resort to the "speed wire mod" to allow the nav in moton?
    Thanks,
    Mike
  7. krg03
    krg03 Not expert, just experienced
    246
    31
    so cal
    Nav version prevents it.
    Speed wire mod is a way. CoatalTech sells a mod also. Speed wire mod is the cheapest. Do some reading you will see some funny things that happen when you disconnect the speed wire while moving.
  8. jclove
    jclove New Member
    Burbank, CA
    I have a 2008 Prius with all the options. The hack to disable the Navigation lock-out doesn't work for me. The "diagnostic screen" never appears. Any suggestions?
  9. Ryder99
    Ryder99 Member
    53
    60
    S.E. PA
    2022 Prius
    The dealer told me the only easter egg on my 22 was the auto down windows.
