Lithium traction battery degradation - 2012 plugin
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by willyag, Jan 18, 2018.
  1. Prodigyplace
    12,717
    11,849
    Central Virginia
    If I had a PiP in Florida needing a battery, I would see if Todd from Tampa Hybrids could find a good used one.
  2. Yea Right
    Yea Right Active Member
    232
    115
    Seattle
    2014 Prius Plug-in
    IMHO, by the time a battery needs to be replaced, its probably time to consider a new car. Especially with how battery technology is going.
  3. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Have you or someone had a look at the bus bars on the battery? Corrosion can also cause capacity loss.
    I don't know about the PiP battery but the regular gen 3 battery's bus bars easily corrode...
    Prodigyplace likes this.
  4. Mendel Leisk
    42,355
    I wish there was an easy way to sneak a peak at them.
  5. bisco
    52,863
    was there any point to this thread?(n)
    CaliforniaBear likes this.
  6. Mendel Leisk
    42,355
    That's crazy talk...
  7. bisco
    52,863
    agreed, i think that might have been the point as well.
  8. QuantumFireball
    QuantumFireball Active Member
    420
    269
    Ireland
    There's not much you can do with "maintenance" - Li-ion batteries have a shelf life, so will degrade with time regardless of how they are stored or maintained. The only real solution is to manufacture new batteries, which probably won't happen (unless a third party does).
  9. Prodigyplace
    12,717
    11,849
    Central Virginia
    It is unknown whether Gen 4 Prius Li-Ion battery modules would work in a PiP.
    We know the Ni-MH Gen 4 ones work in previous generations. Do not mix generations of modules within a pack though.
    QuantumFireball likes this.
  10. Roy2001
    Roy2001 Active Member
    371
    158
    Sacramento, CA
    Battery is under 8/10 year warranty isn't it?
  11. Prodigyplace
    12,717
    11,849
    Central Virginia
    Not if it isn't installed in the original vehicle.
  12. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    Oh for sure. I was referring to long term ownership after that (8 years for me in Texas).
  13. bisco
    52,863
    but the warranty is only good if the car throws a code.
    jerrymildred likes this.
  14. Pyrofer
    Pyrofer Junior Member
    London
    My 2014 PiP just "suddenly" lost a few miles. I am very frustrated, when I purchased the car it was advertised here as a "15 mile EV range" but it was 12.1 or so from new. It rapidly dropped to 11.x and then later to 10.9 ish on a full charge. It stayed like that for quite some time.
    Recently I got in, and saw the range just suddenly drop and now a full charge is only 8.5.
    The car hardly has 30k miles and is only just 3 years old, do I have a right to be annoyed by this or is 8.5 expected at this point?
    It's winter here but the temp is still 10'c+ so it's not like its super cold.
  15. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Actual or Estimate ?
    As for advertised, the official rating is 11 miles.
  16. Pyrofer
    London
    8.5 estimate when fully charged, but driving shows that to be pretty close to the actual range too, possibly a bit over (real may be 8 or less).
    Official rating from where? I definitely was told it was 15 when I purchased the car, but I remember seeing 12 or 13 on some paperwork, I have never heard 11 as an official figure. I wonder if it was updated?
    Basically, I feel 8.5 is too low for a 30k car. Is it me or is this "normal"? My worry is that maybe there is a bad cell and I should have it looked at by the garage, but if it's me being silly I don't want to pay for a needless checkup.
  17. Prodigyplace
    12,717
    11,849
    Central Virginia
    Footnote 4 says
    4. Prius Plug-in EV Mode is a blended operation of electricity
    and gas and can work under certain conditions up to 11 miles on a full charge
    From the sales brochure.
    http://www.coxtoyota.com/public/images/clp/brochures/pdf/2014-priusplugin.pdf
    Raytheeagle likes this.
  18. bisco
    52,863
    there is no 'normal', because range depends on operating conditions. temp is very important, acceleration, speed hills and etc.
    you would have to have done some early range experiments to know what is going on.
    i get between 10 and 15, depending on outside temp, but that is all local driving at 20-40mph, with few stops.
    how long have you owned it?
    Data Daedalus and jerrymildred like this.
  19. john1701a
    12,840
    5,312
    58
    EPA rating, the value down on the sticker-price.
    Whomever told you was misinformed or misleading.
  20. Pyrofer
    London
    Its just 3 years old, bought new. It's all city stop star driving and it has previously been around 10/10.5 as an accurate range.
    My concern is why it suddenly dropped. I charge it one morning, 10.5, I charge it the next and 8.5. I don't consider 10'c to be cold (current temps in London).
    Nothing changed suddenly other than the estimated range, not the temp, conditions or driving. It just decided it had less range one morning and has not gone back. If it had been a gradual depletion I wouldn't worry but it was the fact it was so sudden (between 2 charges on 2 days.
