Little Battery isnt being charged...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by piggy12346, Mar 16, 2017.
  1. piggy12346
    piggy12346 New Member
    ohio
    And the shop says replacing the big battery is the fix?
    I've been having trouble with it shutting off on me in the middle of driving, and the shop said that its giving an error code for the hybrid converter (or something), and that it is a part in the large battery. They want to change the big battery. From what I've been googling, this doesn't seem to be the case. Can anyone explain if that is either right or wrong?
    52,475
    welcome!
    doesn't sound right. is this a toyota dealership? how many miles on her?
    ask them for the codes and post them here.
  3. piggy12346
    ohio
    I called, 2 error, PA1D, 3110.
    Hybrid control module, and hybrid ECU.
    Not a dealer, 125k miles or so i think.
  4. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    There is a maintenance screen, I use a Scangauge II, or a multimeter on the battery itself to show 12 volt battery voltage.
    When the car has been off for 8 hours, and you are not in READY, the voltage should be near 12.5 volts, let us know.
    Once you put it in READY, it should jump to near 13.8 volts, let us know.
  5. ChapmanF
    18,659
    Negatory. The converter is in the engine bay, a part of the inverter/converter assembly (very visible large box with shiny cover, next to the engine).
    -Chap
    RCO likes this.
  6. bisco
    52,475
    others may correct me, but you may need to go to a dealer for correct codes. how proficient are these gals in prius repair?
    RCO likes this.
  7. ChapmanF
    18,659
    Did I miss that they were gals?
  8. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Guys, gals, does it really bother bisco? Another thread came out from him as gals yesterday, so I think it's an auto correct error that has taken over his phone. (n);)
  9. bisco
    52,475
    thanks for paying attention. if i wrote 'guys', would anyone ask why?:)
    Raytheeagle, RCO and WilDavis like this.
  10. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Why, the gals of course!
    bisco and Raytheeagle like this.
  11. bisco
    52,475
    exactly.:cool:
    RCO likes this.
  12. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    I would ask for clarification of the "or something", or/and change dealer to one who knows about Prii. BTW Welcome to PriusChat (where most of us know at least something about Prii! ) Good luck!
    #12 WilDavis, Mar 18, 2017
    RCO likes this.
  13. WilDavis
    2,493
    2,155
    49
    Perhaps @bisco has a LusciousGarage fixation?
    RCO and bisco like this.
  14. bisco
    52,475
    fixated with pretty much anything luscious.;)
    RCO, WilDavis and Raytheeagle like this.
  15. CooCooCaChoo
    CooCooCaChoo Senior Member
    962
    542
    Cow-lee-fornia
    2023 Prius
    Could be the 12v battery is so old it no longer holds a charge. Have you had to jump it regularly?
    RCO, WilDavis and bisco like this.
  16. cyberpriusII
    cyberpriusII Maybe it was the roses
    1,157
    1,841
    Hyampom
    Watch it -- boys!
    bisco and RCO like this.
  17. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Just another way for the "system" to divide us..
  18. uart
    uart Senior Member
    4,220
    1,211
    Australia
    Be careful with this workshop, they shouldn't be replacing the hybrid battery over this. (Is it possible that they said the inverter but you misunderstood?)
    Anyway. It's most likely one of the following:
    1. The small 12V battery.
    2. The DC-DC converter (part of the inverter).
    3. The inverter coolant pump (as it shuts down the DC-DC converter when the inverter overheats).
    Please check that the inverter coolant pump is working before doing anything else. See: maintenance and repair in Anchorage AK | PriusChat
    Also check the 12V battery voltage. You should see around 13.7 to 14.2 when the Prius is switched on (ready mode). This is a very easy DIY, with or without a voltmeter/multimeter. See: Weird stuff happening? MPGs dropping? Test The Battery | PriusChat
    #18 uart, Mar 19, 2017
    RCO likes this.
