Load test results, cell replacement, only 1 bad cell module?!
Discussion in 'Gen 2 Prius Main Forum' started by Totallylost, Feb 18, 2018.
  1. Prodigyplace
    12,711
    11,848
    Central Virginia
    They used a hobby charger charging one module at a time and balancing manually. A grid charger like the Prolong one from Hybrid Automotive speeds the process immensely, especially when used with their intelligent discharger. @jeff652 has developed a very good system.
    jeff652 and kenoarto like this.
  2. Totallylost
    Totallylost Member
    46
    42
    silver springs
    thank you for your feedback. This is 1st attempt and still have not "put back together", so I haven't gotten to the "fun" part yet or have someone to blame for a patched job as of yet ...lol. I will keep everyone posted though. Let's see how it goes.
  3. Totallylost
    Totallylost Member
    46
    42
    silver springs
    Hi and thank you for your feedback. Yes, the Prolong charger and discharger were ordered for me as a Valentine's gift. It is arriving today and I hope all goes well. I will keep everyone posted. Thank you :)
    kenoarto and Prodigyplace like this.
  4. Totallylost
    Totallylost Member
    46
    42
    silver springs
  5. Totallylost
    Totallylost Member
    46
    42
    silver springs
    I think this message was not intended for me,I'm confused with how messages working on Prius chat:) thank you though.
  6. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    Having read the many threads on battery repairs, it is fairly clear that cell replacements are lasting about 6 months, then another and another are needed every once in a while. This renders the car to a working, but unreliable condition. So the current math is: Prolong system $700 + good cells cost about $35 ~ $800 for the first repair plus $75 every 6ish months forever! And each repair takes 2-3 days of hard work with very heavy lifting. So two years will cost about $1000 vs $1650 for a battery that will work reliably for another 12+ years. Doesn't sound like "fun" to me!
  7. Prodigyplace
    12,711
    11,848
    Central Virginia
    Be sure to take your time, especially letting the pack rest before testing it.
    We had one user here who got impatient even though he knew better. He ended up replacing the battery pack. :eek:
    Totallylost and kenoarto like this.
  8. Prodigyplace
    12,711
    11,848
    Central Virginia
    Regularly using the Prolong reconditioning system changes that scenario. People have got much longer life from the battery pack when reconditioned regularly.
    It makes little sense to use the Prolong system only for repair and then neglect until the next failure.
    Totallylost likes this.
  9. kenoarto
    398
    Chicago, IL
    I very much like the theory of the grid charging systems, but I am not convinced they do anything more than provide a placebo effect. A double-blind test, with a hundred cars or more, should be completed before any claims of value can be established. Especially at $700. It sure would be nice to hear from a couple dozen priuschatters who have used grid chargers to chime in. When and why did they get them? Were batteries replaced anyway?
  10. Prodigyplace
    12,711
    11,848
    Central Virginia
    I have read of some that have seen improvements after several cycles. I know @Raytheeagle uses one. He can likely remember other names.
    Raytheeagle likes this.
  11. kenoarto
    398
    Chicago, IL
    Ya, I've read a few anecdotal reports of short-term positive, albeit inconclusive results. I've also read reports of brief success followed with battery replacements. $700 is a big gamble.
  12. Prodigyplace
    12,711
    11,848
    Central Virginia
    I do not recall any of the latter other than @jerrymildred who I mentioned in post 27.
    You have been here longer than I though.
  13. kenoarto
    398
    Chicago, IL
    And then there is JerryMildred's catastrophe! Who would have known that driving the car soon after doing a routine charge would have totally destroyed his battery? I've read the Prolong instructions, and they sure don't mention that!!! Yikes!
  14. kenoarto
    398
    Chicago, IL
    Best choice for DIY for Gen 2 & 3 HV battery is a full new pack from Toyota at $1625. There is also an experimental kit for $1600, available in limited quantities, from a new vendor here on priuschat.
  15. Totallylost
    Totallylost Member
    46
    42
    silver springs
    thank you :)
  16. Prodigyplace
    12,711
    11,848
    Central Virginia
    They do mention that as a recommendation. Perhaps @jerrymildred can convince @jeff652 to make it a mandatory part of the process.
    If you are not going to discharge the pack, we recommend waiting 30 minutes after disconnecting the charger before driving the vehicle.
    From Prolong Grid Charger User Guide - Hybrid Automotive
    jerrymildred likes this.
  17. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Good luck with the rebuild.
    Also the $1625 from Toyota is not a number most people can get. Toyota reduced their wholesale pricing by about $300 on January 1st 2018. Meaning your total install cost if performed at a dealer should go down that much. If you walk up to a counter and want to buy one, they do not need to give you the new lower wholesale price (which is higher than $1625).
    We are in a pretty cool time for battery tech. When the whack-a-mole game is no longer fun, you can then decide if you want to keep the car and spend the money to do it right, or to junk it, or to whack another mole and trade it in for a new Prius. :)
    jerrymildred and Dxta like this.
  18. Prodigyplace
    12,711
    11,848
    Central Virginia
    Thank you for a rechargeable battery expert opinion here. I know many, including Prius experts here have put many trouble-free miles on your new cell kits. @ericbecky put over 3000 miles on one before he put in another pack to trade in the car for a newer work car.
  19. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    And now his pack is doing charity work keeping a customer's car alive as a loaner
    Prodigyplace likes this.
  20. golfmk681
    golfmk681 Active Member
    264
    105
    los angeles, ca
    So the prolong system temporarily (for 6-12 months) prolongs a failing battery? Just asking for my own knowledge and understanding
