Location and access to 12v battery?
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by ppimd, Apr 22, 2017.
  1. ppimd
    ppimd Member
    122
    Maryland
    Can someone tell me when Toyota placed the 12 V battery in the Gen 2 plug in? In Gen 1 it's in rear hatch area hidden below various trim pieces and difficult not impossible to removed due to it sitting low within the recess below hatch floor level against side inside wall of car., thank you.
    52,386
    when, or where? gen 2 plug in (aka prime) has the battery under the hood, same as gen 4 prius.
    idk when they did it, but it was when they started making the gen 4 and prime. (aka gen 2 plug in)
  3. ppimd
    ppimd Member
    122
    Maryland
    Thanks , placed in rear with Gen 1 PIP for weight balance?
  4. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,304
    3,519
    Anaheim, CA
    Oh you are a rascal, aren't you!!
    bisco and priuscatprimeguy like this.
  5. bisco
    52,386
    they couldn't fit it under the hood. in the gen 4, they shrunk the inverter substantially, allowing space for the 12v.
    dalcon95 likes this.
  6. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    :confused:
    ok, so now I'm confused, please describe Gen 1, Gen 2, Gen 3, and Gen 4:confused:
    Prius from Dad and bisco like this.
  7. bisco
    52,386
    gen 1 prius = sedan.
    gen 2 prius = hatch back.
    gen 3 prius = hatch back, but along comes c and v, then plug in. very confusing.
    gen 4 prius = hatch back, and prime. some are calling gen 3 plug in gen 1, and prime gen 2.
    now i'm confusing myself.o_O
    priuscatprimeguy likes this.
  8. Prodigyplace
    12,675
    11,829
    Central Virginia
    I must have fallen asleep I remembered the Prime as the Gen 2 plugin. We are up to Gen 4 already???
  9. priuscatprimeguy
    2,730
    2,640
    go on..........
  10. bisco
    52,386
    i did, it took a lot more thought.:p
  11. priuscatprimeguy
    2,730
    2,640
    :mad:
  12. bisco
    52,386
    and you thought packages 1, 2, 3, 4, 5, 6 vs I, II, III, IV, V, VI were confusing.:rolleyes:
  13. Mendel Leisk
    41,898
    I think it went off the rails when the Prime was equated to "gen 2". How about "gen 4 plug-in"?
    davidtm, bisco and priuscatprimeguy like this.
  14. priuscatprimeguy
    2,730
    2,640
    I would like a detailed description of those too!:confused:
  15. priuscatprimeguy
    2,730
    2,640
  16. bisco
    52,386
  17. Tideland Prius
    16,615
  18. AnneLW
    AnneLW Member
    118
    95
    California desert
    Shopping for a new Prius now and I am a little confused. by this thread.
    Is this the battery equivalent to the the 12 V battery in my Gen 2 that is under the luggage compartment?
  19. Mendel Leisk
    41,898
  20. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    Yes. The 12V battery had been under the rear deck, but that changed in 2016 with the Gen 4 because they finally made room for it where most cars locate their 12V battery -- under the hood.
