location for dark grey "earth screw" for 2005 Prius hv battery
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by wddanie, Oct 17, 2017.
  1. wddanie
    wddanie Junior Member
    58
    Atlanta
    Does it matter where the dark grey "earth screw" for my 2005 Prius hv battery is installed? If so, what is the correct location for the earth bolt? I recently installed a new battery and forgot which hole the earth bolt was located in.
    Thanks,
    Doug
    SFO likes this.
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,812
    Clearwater, Florida
    Have not heard the term "dark gray earth screw" concerning the hv battery ever mentioned on this site before.The battery itself is not commoned to the car chassis just the case. The battery is isolated from car.
    In the future use your smart phone and take pictures of everything you see at every stage.
  3. JC91006
    16,498
    8,408
    It goes behind the driver's seat. First spot
  4. JC91006
    16,498
    8,408
    All the mounting bolts to the battery are the same, except for that 1 gray "earth" bolt. It would be confusing for a first timer when taking the battery apart.
    Prodigyplace likes this.
  5. edthefox5
    10,096
    4,812
    Clearwater, Florida
    These are all case bolts that bolt the case to the car?
  6. JC91006
    16,498
    8,408
    yes case bolts
    edthefox5 likes this.
  7. edthefox5
    10,096
    4,812
    Clearwater, Florida
    I think I remember one bolt the one thats used to secure the cover for the relays to the floor of the car that has a different colored bolt.
    Btw, JC how difficult is it to take the cover off the battery case without taking it out of the car? Can you get to all the bolt heads or does the whole box have to come out to get the cover off? Thanks.
  8. JC91006
    16,498
    8,408
    It's very easy to take the cover off, 2 bolts on 1 side, 2 nuts on the other. Then 3 more bolts on the side holding the ecu compartment. All 10mm. Then use a 12mm to remove all the case mounting bolts
    You might want to remove the rear seats for easier access.
    #8 JC91006, Oct 17, 2017
  9. wddanie
    58
    Atlanta
    Thanks for the location of the grey ground screw. I will move it to the original location.
  10. Mavi
    Mavi Active Member
    484
    285
    San Diego,ca
    2020 Prius Prime
    Wait.. first spot or the second spot? Does this matter ? I put it in the middle one.
  11. JC91006
    16,498
    8,408
    It doesn't really matter, it goes on the first spot
