Location of body weep hole exits?
Discussion in 'Gen 2 Prius Main Forum' started by tnthub, Jun 19, 2011.
  1. tnthub
    tnthub Member
    519
    Brunswick, Maine
    So my 2007 sloshes around like a frat boy after a keg party. I ran my fingers along the underside of the body and cannot seem to locate the body drain exit locations. Anyone have an idea where they might be hiding?
  2. Patrick Wong
    18,200
    6,474
    The trapped water is likely in the cowl below the windshield wiper arms. You will need to remove the wiper arms and the two-piece black plastic cowl to reach the two drains which are at either corner of the cowl. Frequently, small tree leaves and other debris will clog the drain holes.
    Alternatively, water may be trapped in a door but if this is the case then you should hear the water sloshing around when you move the door open and closed.
    ChrisFaehrtPrius likes this.
  3. tnthub
    tnthub Member
    519
    Brunswick, Maine
    Thanks for the response. :)
    I already did the above and the drains were clear. The water sound is coming from what sounds like behind the dash. Standard cars have weep openings where the body molding goes by the frame. The Prius appears to have a plastic molding which I "assume" prevents whatever is contained in the plastic from getting wet.
    I could gently pry back the edge of the plastic to feel along the metal ridge where weep holes are normally found but came up empty in my search.
    The doors are dry.
    My only thought is the drains are working in terms of water going into them but plugged where they exit. :confused:
  4. hyo silver
    hyo silver Awaaaaay
    15,232
    1,563
    off into the sunset
    That doesn't sound likely, because the tubes by themselves don't hold enough water that you'd hear it sloshing around. Have you checked under the spare tire? I know, you said the sound seemed to be coming from the front, but under the spare is another place water has been known to collect.
  5. richard schumacher
    7,663
    1,038
    United States
    If it seems to be behind the dash, possibly the air conditioner evaporator is filled with water because its drain is plugged. Have a shop suck the drain tube clear (the usual procedure is to blow air into the drain tube, but that will push any crap in the tube back up into the evaporator).
  6. tnthub
    tnthub Member
    519
    Brunswick, Maine
    Thanks guys. I'll try and have my wife convince the mechanics at work to check it out tomorrow (she is a saleslady at the local Toyota dealership).
  7. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    Yeah suck it out with a wet vac. Seen that done alot on home units works good but I'm with the water in the trunk myself.
