Lock your Prius and go Surfing...
Discussion in 'Gen 3 Prius Main Forum' started by FranSalinas, Aug 29, 2012.
  1. FranSalinas
    FranSalinas New Member
    I need to find a way to lock my 2010 with the key fob inside so I can safely go surfing with the tiny key in my wetsuit pocket. I thought that manually locking the door with the key, after leaving the fob inside would work, but it doesn't.
    Thanks,
    Fran
  2. PaJa
    PaJa Senior member
    678
    116
    92
    Czech republic
    The metal box inside the car for the FOB storage will be sufficient.
  3. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    I recall reading this same request sometime back. IIRC, the advice was to wrap the FOB in foil and then place in a metal box somewhere in the middle of the car. This puts it as far from the transponders as possible while still being in the car.
    SurfersPrius likes this.
  4. phoenixgreg
    phoenixgreg Senior member
    1,157
    295
    66
    Phoenix
    Anyone remember the "Hide a Key"? Someone should invent a "Hide a Fob"
  5. gliderman
    gliderman Active Member
    751
    225
    There are numerous waterproof pouches for fobs. A google search found lots of good ones.
  6. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    Take the battery out of the FOB and then leave the FOB in the car and take the hard key surfing. The FOB will still start the car if you hold it near the start button while pushing the button. Happy surfing!
  7. FranSalinas
    In my experience these tend to be bulky and unreliable. Maybe they're good for a swim in calm waters but in the surf they are not comfortable, and I don't want to trust one of these.
    Thanks to all of you for your help I'll try your suggestions and post results soon.
  8. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    You could get one of those door knob type key boxes that realtors use and secure it to your rear towing eye with the fob inside that should shield it enough.
    Posted from my iPhone via the Tapatalk app.
  9. Dorian7
    Dorian7 Junior Member
    70
    16
    Due to the inconvenience I suggest you give up surfing -- Problem Solved.
    PriusIndia, Tony D and prominence like this.
  10. h00ktern
    h00ktern Member
    135
    40
    This is the best solution for a few logical reasons.
  11. Southern Dad
    Southern Dad Active Member
    350
    212
    58
    Monroe, GA
    I like the realtor type box solution.
  12. FranSalinas
    I agree this is the way to go for me, tried it today and it works,, simple, easy and unexpensive...
    No way I give up surfing... I'd rather walk to the beach!!
    Thanks dudes!! ;-)
  13. sLick415
    sLick415 Member
    214
    55
    San Francisco, CA
    There should also be an option in your settings to turn off the smart key system. Unless that's just in the 2012.
  14. austingreen
    austingreen Senior Member
    13,710
    4,230
    Austin, TX, USA
    I have foil that I wrap it in, then put it in the cargo compartment. It works for me. But I don't need to do it daily.
  15. texasboy77904
    texasboy77904 Junior Member
    92
    I was having the same issue last week while getting ready for my first sesh with the prius. Took me 20 mins to find a place to store the key outside the car.
    Will the hard key rust out easily? How do you remove the fob battery?
  16. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    The metal key sould not rust most are brass under the silver finish. To remove the fob battery take out the metal key and look along the seam of the fob for a small notch, insert the end of the key and twist the key to open the fob by seperating the halves. Once appart remove the battery and put back together carefully the fob is water reistant if put back together correctly.
  17. texasboy77904
    92
    Thanks mate!
  18. David Felix
    David Felix New Member
    Kailua, Hi
    Secret Surfer Prius Fix: Take surfboard out of car. Take the hard key of of the FOB. Hide the FOB anywhere in the car. Close all the doors. Now lock the driver side door with the hard key. Test to see if car will unlock by touch. Lock hard key in key box or take it surfing with you. Please Read Disclaimer - "not responsible for any stolen Prius's and less then desirable surf conditions" FCS
  19. EvanB
    EvanB Junior Member
    39
    Phoenix, Arizona
    2014 Prius Plug-in
    I had a similar thought about this issue. My conclusion was to leave fob and home and just deal with the hard key on those beach / water activity days. I don't want to rely on foil block all of the signals.
    However I do notice when I have my cellphones in my pocket and the fob goes behind them I get a key not detected error sometimes.
  20. austingreen
    13,710
    4,230
    Austin, TX, USA
    Gen III won't start without the fob. I wrap mine in foil, I've had the same piece of foil in my car for years. For us active types it would be nice if there was an off switch, which i belive is on the gen II.
