Lockdown Cuisine Thread
Discussion in 'Fred's House of Pancakes' started by Leadfoot J. McCoalroller, Apr 15, 2020.
  1. ChapmanF
    18,942
    Yeah, but where does #3 come in?
    Haven't tried it for that. One noticeable feature is that the lid has a sealing ring made of silicone, and this will retain what you could only call an unkind caricature of the smell of whatever you cooked last. You can kind of fix it by running a batch of white vinegar and citrus peels, which doesn't make the odor go away, just turns it into a caricature of vinegar and citrus, which is often an improvement.
    I'm not sure I want to know what an Instant Pot caricature of EGR cooler smells like.
  2. Leadfoot J. McCoalroller
    8,263
    7,767
    Pennsylvania
    2018 Prius c
    My sister in law got an instant pot and has reported the same sorts of success.
    Meanwhile we took the other side of the cointoss and got an air fryer. We've had it long enough to figure it out. I remain impressed by the base claim and performance: deep fried flavor with a teaspoon of oil less.
  3. ETC(SS)
    7,485
    I have a Mk-1, Mod-1(*) stovetop pressure cooker that I keep on hand for canning - something that I really do not do much of because a lot of our pantry staples are shelf safe faaaar beyond the 'sell-by' date, and I'm not THAT much of a prepper.
    * Mk-1, Mod-0 (original) pressure cookers used to have a scary hissing weights on them.
  4. RRxing
    RRxing Senior Member
    2,562
    1,839
    NEPA
    Recently bought a Breville Air Fryer Smart Oven and made some delicious zucchini sticks. Gonna try air-fried chicken soon.
  5. Leadfoot J. McCoalroller
    8,263
    7,767
    Pennsylvania
    2018 Prius c
    I've learned that I can't (so far) beat the fried chicken from the fancy fryer at the deli counter in the supermarket. But on the other hand, I can buy theirs, freeze half of it, and rejuvenate it in the air fryer. And it's miraculously good. Can't tell the difference between fresh and months in the deep freeze when I do it that way.
  6. RRxing
    2,562
    1,839
    NEPA
    We're just trying to avoid using oil/grease. The zucchini sticks came out surprisingly crispy w/o oil.
  7. hill
    9,013
    different generations .... as kids of the 1960s, we remember our moms going healthy. Switching from lard, & then to Crisco. LOL
    To this day, it's still no easy task to NOT scramble eggs in the bacon grease. Yum yum!
    Mark57 likes this.
  8. ChapmanF
    18,942
    I remember the pressure "cookers" that came with two or three different weights to sit on top of the vent tube. The opening had a certain area, divide that into the chosen weight, that's the pressure you get.
    I have a larger pressure "canner" that came with only one weight (the 15 psi one) but has a pressure gauge in the middle of the lid that reads psi on a dial. In normal use there's no steam escaping under the weight, and you really can dial in any pressure you want, by watching the gauge and adjusting your burner input under the canner.
    It's kind of fun working out how that can be. There's a whole evaporate-circulate-condense sort of climate system closed up in there, whose only energy input is from your burner beneath the pot, and only energy output is heat lost through the walls, and by changing your one input you're driving that whole enclosed system to a different equilibrium pressure.
    The Instant Pot is in that family. It only comes with a single weight sitting on the vent tube. It has no visible pressure gauge, but an internal sensor, and the firmware modulates the heating input to hold a target pressure.
    Beyond that, they build in a lot of features to make it more foolproof. There's a 'vent' button that mechanically pushes up the weight to let the pressure off so you can get your meal out faster than waiting for natural cooling, and you can move the button without your hand being near the weight where the steam will escape. The weight is under a plastic cover with a ring of holes not directly above it, so escaping steam has to take a longer path under this cover, and a lot of condensation happens in there, so if your hand does get in the path, it packs a lot less latent heat of vaporization to deliver to your skin. There's a pair of mechanical interlocks so (a) when pressure is inside you can't rotate the lid to try to open it, and (b) any rotation of the lid also lifts the weight. Inside the lid, the vent tube has not just one opening but a set of cut channels, and there is a screen over it, all to reduce the chance that one random bean blob blocks the whole vent and leads to overpressure. Plus the microcontroller will detect any excess pressure at the sensor and turn off the heat and display an error.
    Overall they did a lot to make it convenient and non-scary.
    Pressed the yogurt button out of curiosity last night. Darned if it didn't make yogurt.
    Now I have a lot of yogurt.
  9. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    The wife got a Ninja Foodi from Costco yesterday :).
    The dehydrating feature is the first up to try;).
    I'll post up some results when they are available (y).
  10. Leadfoot J. McCoalroller
    8,263
    7,767
    Pennsylvania
    2018 Prius c
    I don't have an instant pot cooker, so I can't try this one myself.
  11. RRxing
    2,562
    1,839
    NEPA
    Is the "Clear Packing Tape" to cover your mouth so you don't have to drink this abomination? :D
  12. Leadfoot J. McCoalroller
    8,263
    7,767
    Pennsylvania
    2018 Prius c
    Honestly no clue. I haven't got one of those, so I'm posting it in the hopes of getting a report from someone who has tried it.
    Click on the graphic to get the full instructions.
    I'd be welcoming a better recipe in your next post- doesn't have to be wine.
    Tonight we are doing Alton Brown's gyros with tzatziki recipe. I've got a cheap charcoal barrel grill that I modified with a 36" rotisserie setup. It's the first time we've tried this one, but we've had great success with Brown's other recipes so we are fairly confident in this one.
  13. ChapmanF
    18,942
    To make a poor-man's 'aerator' on top of the bottle you'll use for the ~ month of fermentation after the two days in the Instant Pot.
    I haven't tried it, but the recipe author reported decent opinions from a couple people who did.
    I only have the one pot, and it's currently occupied making something like my old chili recipe minus the bits I don't have at the moment. So no wine for me. I found a cache of seriously old dried beans.
  14. Leadfoot J. McCoalroller
    8,263
    7,767
    Pennsylvania
    2018 Prius c
    I only just discovered this: Add a teaspoon of baking soda to your dried beans as they cook. A more alkali gravy shaves hours off the softening clock and lands you at a great texture.
  15. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Here's the first dish out:):
    Steak wasn't the best cut, but still turned out well;).
    And easy cleanup(y).
  16. Leadfoot J. McCoalroller
    8,263
    7,767
    Pennsylvania
    2018 Prius c
    You're reminding me, I didn't put in the picture of the gyro meat we did last night. Today we brought it back for lunch leftovers, I cooked up some rice with turmeric and served it NY street style.
    Raytheeagle and Mendel Leisk like this.
  17. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    That looks really good:).
    I bet it was very tasty;).
    Hang in there and keep the cuisine pics coming(y).
  18. Leadfoot J. McCoalroller
    8,263
    7,767
    Pennsylvania
    2018 Prius c
    You bet! we did something not picture-worthy tonight but I'm thinking I might do my 8-hour smoked wings this weekend.
    Raytheeagle likes this.
  19. bwilson4web
    16,512
    Kraft macaroni and cheese, two boxes, with a tin of minced clams, extra white cheddar, and a dollop of sour cream.
  20. RRxing
    2,562
    1,839
    NEPA
    From the Cardiologist's Cookbook :ROFLMAO:
