locked out my car and trunk
Discussion in 'Gen 2 Prius Technical Discussion' started by roostercruiser, Oct 7, 2012.
  1. roostercruiser
    roostercruiser Junior Member
    24
    denver
    My smart key doesn't work on doors anymore. And inside power locks don't work either? ???????. Can't open trunk. It just qiut working without warning. Smart key still starts the car thou. When i put my hand in handle it just beebs. And little black dots on doors inop also. Any ideas .
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  3. roostercruiser
    24
    denver
    Everything else works in the car. Would a battery just effect the locks. ?
  4. MJFrog
    MJFrog Active Member
    780
    267
    NE Oklahoma
    2018 Nissan LEAF
    Yes. Do the battery tests. If they turn out OK, try replacing the FOB battery. ;)
  5. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    Do the dome lights work the body ECU appears to be fed by the dome light fuse.
  6. roostercruiser
    24
    denver
    Cant get trunk open to check battery . Dome lights do work
  7. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    You don't need to open the trunk. It can be checked via the MFD. You need to tell us 3 voltage values.
    It's best to check it after the car has sat overnight from being last driven. If it's already in a bad state and hasn't been driven already, then this is a good time.
  8. Britprius
    5,194
    1,922
    You can check the 12 volt battery with a DVM at the red jump point in the fuse box under the hood.
    You can open the trunk by climbing into the back of the car and operating the small lever just below the lock mechanism. (If your a contortionist)
  9. roostercruiser
    24
    denver
    Wheres that located?
  10. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    When standing in front of the car and looking into the engine compartment, it's under a black plastic cover/lid on the right side. It's all in your manual, under the jumping procedure.
    Again, you can get a voltage reading via the MFD (touchscreen LCD). Although that may not be the most accurate, it'll tell us something useful, if it's very low. Procedure in post 2.
  11. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    The 12 volt battery would effect everything in the car until you pressed Power. It is possible that locks are all you do before pressing Power.
    The Fob battery would not effect the small black squares, so I did not consider it.
    Honest, the entire test procedure is in Weird stuff happening? MPGs dropping? Test The Battery | PriusChat
  12. roostercruiser
    24
    denver
    Ill check tomorrow. What 3 values?
  13. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
  14. fabulent
    fabulent New Member
    Virginia
    How do I open the car if the Prius doors are locked and 12V battery is dead?
  15. bisco
    52,691
    there is a mechanical key in the fob.
    you can unlock the drivers door, and crawl in back to open the hatch with the safety release on the inside.
    or you can pop the hood, and put a 12v source on the jump point.
  16. fabulent
    fabulent New Member
    Virginia
    thanks bisco. I think I can open the car now. However, how do I charge the 12v battery?
  17. bisco
    52,691
    you need a small charger 2-4 amps i think. or you can call an auto parts store to see if they can charge it.
    how old is it? you might want to replace it.
  18. fabulent
    fabulent New Member
    Virginia
    this prius is a '08
  19. bisco
    52,691
    how old is the battery?
