Locking charging cable
Discussion in 'Prime Plug-in Charging' started by ricomtl, Mar 22, 2019.
  1. ricomtl
    ricomtl Member
    137
    39
    moon
    2018 Prius Prime
    Technology
    I'm scratching my head here o_O I've read several times the locking features of the charging cable in the user guide but I'm still not getting it!
    At home, I use a EVO Innovate Charger 220V cable. My car is set to auto-lock when cable is plugged in. I hear a click sound when I plug in my cable. If I try to unplug the cable (and FOB is not on me), I am able to pull out the charging cable, without even pressing the charge connector lock button . I've tried all modes, Manual Lock, Auto Lock and Auto Lock & Unlock. No luck.
    Is the lock mechanism only working on the Toyota supplied 110v charging cable?
  2. hill
    9,014
    Why not just go this route?
    krushmoto and ricomtl like this.
  3. ricomtl
    ricomtl Member
    137
    39
    moon
    2018 Prius Prime
    Technology
    That's funny - not looking for a DIY solution. Trying to test what the user guide says!
  4. hill
    9,014
    You can call it DIY, but the hole in the nozzle is there for a reason ...
  5. krushmoto
    krushmoto Member
    65
    44
    US
    I use the Duosida level 2 charger and I programmed it so it will automatically unlock when charging is complete. Perhaps that what you have it set it to?
    If you auto lock only you have to manually unlock to pull out the charger. And I don't think you need the key fob to unlock but I could be wrong.
    moto z3 ?
  6. ricomtl
    ricomtl Member
    137
    39
    moon
    2018 Prius Prime
    Technology
    Ok, I should've done this before. I turned on my flashlight and noticed that the lock pin doesn't reach my EVOInnovate charging cable due to its design! I compared both cables (Toyota OEM and my own) and it make sense now. I should've done this before posting this thread! Sorrry! :unsure:
    Good news is that that's my home charger inside my garage... so I guess the system should work if I ever use a public charger!
    Tideland Prius likes this.
  7. Marine Ray
    Marine Ray Senior Member
    1,139
    949
    Sparks, NV
    This might help:
  8. ricomtl
    ricomtl Member
    137
    39
    moon
    2018 Prius Prime
    Technology
    I already found what the issue - in post #6 - the issue is with the cable, not the car!
    Marine Ray and jerrymildred like this.
  9. MrHockey
    MrHockey Member
    66
    51
    Minneapolis
    2020 Prius Prime
    I did the same and it works fine.
