long beep and brake pressure low
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by karmakid64, Mar 26, 2019.
  1. karmakid64
    karmakid64 Junior Member
    16
    New Jersey
    my 05 started a constant beep the brake light came on and the brake pressure is low also vsc and abs {see attached photo} please tell me its something I can easily fix. if not how much will it cost?
    49,473
    sounds like a leak in your accumulator. but prius brakes are complicated. you need to read the codes with tech stream software (amazon) and troubleshoot with the service manual at techinfo.toyota.com
    the whole shebang is $3500. at the dealer, diy a grand in parts. many people go salvage for a few hundred with decent success.
    if it's just the accumulator, shouldn't be too bad.
    karmakid64 likes this.
  3. karmakid64
    16
    New Jersey
    Thanks for the response!
    I called tampa hybrids in Tampa FL and they said it would cost 2160 installed for an upgraded part because the original is defective? or something to that effect. he said he does not install used ones because they could also fail and that seems fair to me and he has a great reputation here on Prius chat
    but, because im a disabled person living on a fixed income I need the to take/consider the least expensive option
    is there a less expensive solution? Thanks for the feedback!
    49,473
    yes, todd is a great guy from all that I've heard. and that is a great price compared to a dealer.
    iirc, some have mentioned changing the brake fluid can help. see if you can find any threads.
  5. dolj
    dolj Senior Member
    7,652
    3,865
    Wellington, New Zealand
    So, are you not in Tucson like it says in your profile? That an awful long way to drive to have your brakes fixed.
    Depending on whether you had a conversation like, "Can you give me a quote for fixing my brake accumulator?" or more like "I have these lights and symptoms. What do you think is wrong and what will that cost to fix?" with Todd, you might be better to take it to a more local Prius mechanic for a diagnosis, that includes reading the DT codes, and then a solution from that.
    Get a second opinion on that too, just to keep the first guy honest.
    I wouldn't be asking to spend $2-$3,000 just on the strength of one opinion on here.
  6. karmakid64
    16
    New Jersey
    thanks yes I live in Tampa now
  7. karmakid64
    16
    New Jersey
    as of this morning the continuous beep and the dash lights went away everything seems normal but I am still taking it to local hybrid mechanic to scan for codes and diagnostic to see whats going on. he said the diagnosis would be between 69 and 130 dollars.
    I asked if the diagnostic is free if I go with the repair and he said no
  8. bisco
    49,473
  9. TampaPrius.com
    TampaPrius.com Active Member
    461
    296
    Tampa, Florida
    Diagnostics are always free in my shop. If it is the actuator (usually DTC C1256 and/or C1391) I can install the brand new updated Toyota part for $1950 + tax.
    m.wynn and Raytheeagle like this.
