Long Chat with Toyota Mechanic Today
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Matt Herring, Jun 1, 2009.
  1. tochatihu
    tochatihu Senior Member
    9,975
    3,847
    Kunming Yunnan China
    2001 Prius
    There are quite a few used engine oil analyses posted at Prius Chat. From them I can detect no indication of increased engine wear using oil with viscosity less than 5W30.
    The OP's mechanic is aware that the Prius engine is 'spun up' before fuel and spark are applied, I hope. Most cars (with which he is abundantly familiar no doubt) are a bit more brutal about that.
  2. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    I didn't have that trouble in my 240, ran it about 70,000 miles more after that. Seems like I had to select a specific grade of synthetic gear lube though.
  3. a priori
    a priori Canonus Curiosus
    3,083
    408
    23
    Chicagoland (West)
    I had a nice long chat with the Service Manager at my dealer's place earlier this week. First of all, he was quite well aware of the new 2010, and he was very ready to take whatever time I wanted to talk with me about the Gen2 and Gen3 Prius.
    I asked whether we would see a longer period allowed between oil changes, and he said "No!" -- rather emphatically, in fact. His number 1 reason? The black eye Toyota received over the sludging was going to keep Toyota from making any changes to the oil change schedule.
    I've not yet talked with a Toyota sales person or mechanic in this area who knows anything about the EBH. They aren't even aware of the hole in the block. Many have said that it might endanger the warranty, and they've been confused over the fact that the part I have is a Toyota Canada part.
    I'm quite pleased that the guy in charge of the mechanics at my dealership was entirely up-to-speed on the 2010 Prius. Even if he didn't know about the EBH (but was interested in learning more about it), he was way ahead in the "So, I'm a mechanic and you're not -- that doesn't mean I can't learn something new from you" attitude.
  4. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    I made the change on an early 1990's Chevy Caprice, at the time it had around 90,000 miles on it. Within a month, the pinion seal and both axle seals were dripping
    What I learned from that debacle was to either do an *early* initial change, say before 10,000 miles, or leave it alone.
    Lesson learned
  5. ETP
    ETP 2026/2021 Prime/24 Venza Limit/B52-D,G,F,H
    2,806
    1,170
    Auburdale FL
    Anyone use 0W40?
  6. jayman
    13,439
    641
    Winnipeg Manitoba
    I've run Mobil 1 0W-40 European Car Formula in my FJ with excellent used oil analysis results, using a 7,600 mile oil change interval. This is a very good oil, and my FJ motor has a tendency to shear oil
    I'm currently running the made in Germany Castrol Syntec 0W-30 in the FJ. It's also supposed to be a very good oil. I'll sample the oil sometime in Sept or Oct to determine how well it works
    I switched to the Syntec as the Mobil 1 0W-40 is now very hard to find around here. I stocked up a bit before it disappeared, only have enough oil for a couple of FJ oil changes
    There shouldn't be any measurible difference in fuel economy with a Prius running 0W-40. The first summer I had my Prius, I had 3 litres of leftover 15W-40 after changing the oil in the hobby farm tractor and work truck.
    I ran the 15W-40 for the summer, perhaps lost 3 mpg with my '04 Prius. So I wouldn't be afraid running 0W-40. Just not sure if there is anything to gain.
    For most of my '04 Prius ownership, I ran Mobil 1 0W-20 with great results. Excellent used oil analysis results even at 16,000 km intervals
