long term (four month) storage
Discussion in 'Gen 3 Prius Main Forum' started by krausternet, Sep 30, 2021.
  1. jzchen
    jzchen Newbie!
    3,316
    1,022
    Arcadia, CA
    I drive gently and when I come home the HV battery is usually 1 bar from full. I would park it as such and put a battery maintainer on the jump points under hood, with anywhere between 2 A and 4 A range.
    REVVL V+ 5G ?
  2. farmecologist
    farmecologist Senior Member
    1,960
    1,801
    Southern MN
    Absolutely. Use the jump points under the hood. Search around...there are some threads about it here.
  3. Mendel Leisk
    42,345
    Some chargers come with a quick-connect; installing one of those can make charger connection more solid/convenient. Depending on your circumstances might be worth consideration.
  4. farmecologist
    1,960
    1,801
    Southern MN
    True. I use a quick connect on the 2012 Prius C two...because there are no quick connects under the hood ( at least for the 2012 model year. Apparently they added them later on ).
    On the Prius V wagon ( and on our now totaled 2010 liftback ) I use/used the jump points under the hood.
  5. Mendel Leisk
    42,345
    With the near-constant connection and frequent connect/disconnect (of our garage queen...), I got tired of dealing with raised hood, precarious alligator clips, taking off the fuse box cover. Now I can just pop the hood, plug into the adapter, and lower the hood just to.
  6. gboss
    gboss Member
    173
    63
    Mountain Town in CA
    If you’re in the Bay Area, you could put it on Getaround and make a bit of money while someone drives it for you. Just disable booking after it is driven enough for any given month.
  7. farmecologist
    1,960
    1,801
    Southern MN
    Yep..I agree...it can be a bit of a pain.
    I suppose it is also possible to connect the adapter directly to the battery in the back....correct? That way you wouldn't even have to open the hood. (y)
