Long term owners mpg
Discussion in 'Gen 3 Prius Fuel Economy' started by mengoni, Mar 16, 2019.
  1. mengoni
    mengoni Junior Member
    33
    Kansas
    I have a 2010 with 130,800 miles. I bought it used in Dec 2015. I even posted the best tank mpg on the dash with over 58! I haven't seen any mpg change except for seasonal. Just filled up a few hours ago and calculated 52.83 mpg.
    My question for the long term owners is have you noticed any mpg drop in the years you've had your car
    Aaron Vitolins likes this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    We have 198k miles on our 2010 that we bought new in August 2009 and I’ve averaged around 50mpg with most of that at freeway speeds :).
    There were a couple of times when it began to dip with explainable causes:
    • Egr system was plugging up
    • Hv battery was degrading
    • Winter blend of gas
    The egr circuit you can clean with the right tools, the hv battery Hybrid Automotive makes the Prolong equipment. Not much you can do about winter blend gas:cool:.
    Good luck with your new to you Prius (y).
  3. drroone
    drroone Junior Member
    I'm averaging about 42 mpg and have been for a while. I have 128k on it and haven't really don't any maintenance beside oil changed. Any recommendations you'd suggest. I bought the car used and while I first got it I was up in the 48mpg area but it's definitely dropped off.
  4. Raytheeagle
    11,267
    15,526
    2019 Prius Prime
    Is it a winter time thing, or the other factors mentioned above? Hard to know without your location being listed;).
    If the driving trips are not short which hurts mpg, at the mileage you are at the egr cooler is more than likely starting to restrict:(.
  5. MacArthur
    MacArthur Junior Member
    23
    Great Falls, VA
    Same here, 2011 Prius, about 129K, Bought the car in northern VA, could easily go over 60mpg back then.
    Now I'm living in central NJ, Daily commute is around 45miles, mostly highway. It has been around 44-45mpg most of the time in Winter. In summer it's a little better, can go up to 48~49mpg, but never reaches 50 again.
    Guess I'll have to live with it - whatever you do, whether cleaning the egr valve or replacing the hv battery, it all costs money. And MPG just got improved a few extra miles... perhaps I need to drive another 129K to make it up.
    kevin.c likes this.
  6. GardenWeasel
    GardenWeasel Member
    76
    53
    Columbia, SC
    I bought mine new and now have 136,000+ miles. When I quit tracking my FE, I was averaging between 52 and 53 mpg. I hardly ever had/have a tank of fuel that gets below 50 mpg. Tires have made the biggest difference in FE...with my current Michelin Defender’s performing quite nicely.
    Raytheeagle likes this.
  7. ewxlt66
    ewxlt66 Active Member
    535
    186
    Dana Point, CA
    Wife commutes 50 mi round trip in ours. Averages about 49 with LRE tires 10psi over manuf. spec.
  8. CR94
    CR94 Senior Member
    2,822
    1,238
    Northwestern S.C.
    Long-term is holding near 57 mpg actual.
  9. sprintr
    sprintr Junior Member
    chicago il
    I have a 2014 with 150.000 eighty percent expressway average 54 to 61 has gotten better with age. makes me a little nervous.
    Danny3xd () likes this.
  10. jadd806
    jadd806 Member
    45
    34
    MA
    135k on my 2015 Prius with 383 fuel ups tracked, 46.2 average MPG in New England.
    Definite decrease over time but I attribute it to driving faster and caring about MPG less as I've owned the car.
    RMB, frodoz737 and Raytheeagle like this.
  11. Vman455
    Vman455 Senior Member
    540
    556
    The Middle
    If your car is kept in good condition, there shouldn't be any change in fuel economy that isn't attributable to driver practice and external factors (traffic, weather, etc.).
    As an example, at the Green Grand Prix a few weeks ago (so, all cars running on the same closed track under the same conditions), my Gen 3 with 75,000 miles and a few aerodynamic modifications posted better fuel economy than any other non-plug-in Prius there. I got 59.7 mpg; the next closest was a 2019 at 57.5 mpg.
  12. Danny3xd ()
    Danny3xd () Member
    85
    38
    Connecticut
    When I got her, 38 MPG. (2 brake pistons were sticking) 48/49 MPG now.
    Spring time in CT, U.S.
  13. Tekken
    Tekken Member
    260
    77
    Los Angeles, California
    My first tank of gas used up since bought this 2013 Prius about 3wks ago. Display showed 52.2mpg on 502.4mi on Trip A and No Gas tank bar. I'm assuming it has about 1gallon left in the tank.
    All long term owners here filled up with 87 or 92 gas?
  14. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    We've only ever used 87 octane Top Tier gas -- BP, Mobil, Costco, and one tank of Marathon.
  15. Mendel Leisk
    42,289
    Our 2010's mpg has been "fairly" steady. Kinda stumbled outa the gate this spring, due to new tires I suspect. Is picking up again, just wait till next fill up, lol. Only 83K kms (~50K miles) on it though.
  16. frodoz737
    frodoz737 Top Wrench
    4,795
    2,560
    33
    Previous 2010 and current 2015. Best was 61.9 mpg long trip @60 mph flat road, worst 27 mpg long trip @65 mph towing medium weight trailer with hills. Both...about 42 mpg lifetime...driving normal. YMMV...but they both beat everything else without a plug. ;)
  17. CR94
    CR94 Senior Member
    2,822
    1,238
    Northwestern S.C.
    Average for
    2015: 58.0
    2016: 58.2
    2017: 59.7
    2018: 59.9
    2019: 60.0 so far
    However, tires must be replaced soon.
  18. bettergolf
    bettergolf Active Member
    493
    370
    Sanford NC
    after 2 years and 25k miles (50k on the car now) on my 2015 I average 53 in warm weather and 48.5 in winter. Tire pressures all at 39, no special tires, just all seasons not the best but middle of the range tires, buy the cheapest gas (87 octane) I don't care what brand, name brand or brand x. I do pay attention as I'm driving but won't go so slow that I irritate other drivers......I keep it under 72 at all times and try to take off smoothly if not slowly. I notice that if I'm in a hurry on a 35-65 mile trip it'll be 47 mpg (on the dash) and if i'm not in a hurry on that same trip it'll be 10 better.
  19. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    This was my last & best tank w/AC on :cry:. 125K miles w/15,000mi OCI, thanks to non OEM and Mobil 1 oil & filters.
  20. Tha_Ape
    Tha_Ape Active Member
    271
    162
    Washington, DC
    Ive had my 2010 for almost a decade. Best mpg was 59, now I get 45. It might be that I drive it more aggressively (if that's even a thing in a Prius), when I first got it, I was trying to maximize mpgs, then started driving it "normally".
