Long-time intermittent rattle/shaking suddenly became nonstop
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Iketorz, Nov 3, 2025.
  1. Iketorz
    Iketorz Junior Member
    46
    Hey everybody, 2010 Prius, 201,000 miles, engine suddenly shaking/rattling like crazy. The first and most important detail of this problem is this: It's done this exact thing intermittently ever since we bought the car 100,000 miles ago.
    Before, what it would do, is every once in a while (every couple months) we'd move the car in the driveway a few too many times without it fully warming up, and then on one of those startups it'd shake/rattle like crazy. Shut it off, restart, it might do it again for a few seconds but then clear out and run like it's fine.
    Again, this car has done this, intermittently, once every couple months, a few seconds at a time then fine, for 100,000 miles.
    A week ago it suddenly did it in a totally different situation with my wife at the wheel driving home from work, fully warmed up for 20 minutes, suddenly starts doing the same rattle/shake. She pulls over and calls me. I can't get it to go away.
    Over that 100,000 miles, 7 years of ownership, the coolant has very slowly dropped in the reservoir from max to near low.
    I don't think it's the head gasket. I've been a car guy my whole life, fixed all my own old cars for 30+ years including head gaskets, grenaded modified engines and total rebuilds.
    Why not? Because I put it in neutral and the sound and vibration goes away completely, instantly. It now does this hot or cold, all the time, but only does it in these conditions: when it's in park, when it's in forward or reverse, and it's anywhere between idle and half throttle. AKA any time it's charging.
    If I put it in neutral it goes away completely. If I drive it above half throttle it goes away completely.
    It's giving me a code for a "random misfire"
    At this point I'm thinking it's EGR or a horrible transmission/clutch spring thing.
    I've cleaned the EGR system, intake included, twice in this car's life, once at 125,000 miles, then again about 5,000 miles ago. That's throughly blowing out and chemically cleaning out all the passages, the valve itself, the cooler, all that. I tried the EGR valve-to-intake-pipe blockoff trick thing and it didn't change whatsoever. No idea if that truly rules out an EGR system.
    I pulled the ~2"x3" black plastic cover off the underside clutch part of the transmission facing the engine and felt around in there and I can't feel any detritus or broken springs. But there wasn't much room to feel around down there.
    Did the plugs 15,000 miles ago with OEM factory replacements btw.
    Ideas? Thanks
  2. BiomedO1
    BiomedO1 Senior Member
    4,641
    2,435
    Left Coast
    If your getting a P0300, why do you think it's the transaxle or flex plate?????????
    It's obviously an engine problem!!! The question you should be asking yourself is, what's causing this?
    Fuel
    compression
    spark
    You really already know what it is; STOP fooling yourself and verify it. You can talk yourself into a "parts cannon" all you want - bottom line it isn't going to fix the problem you've been ignoring or just don't want to see. Mark your coolant jug, it should be going down very slowly now that it's an on-going issue.
  3. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    SSSssooooo... how much is the price of rice in china???????
    Since you rarely drive it, and don't always allow the engine to fully warm up, condensation and unburned
    fuel could be causing some of the knocking. And perhaps the plugs are fouling now. Thus the missfires....
    How many TOTAL miles on the engine?
    Since the coolant is going down, it's very likely it's the head gasket that has failed.
    But if you insist, you could pull the plugs, clean them, reinstall them. But look inside the cylinders and
    see if the pistons look clean, from the coolant burning. And fill the coolant with the Toyota coolant.
    Then drive the car long enough to fully warm up. And watch the coolant, go down, as the engine knocks...
  4. PriusCamper
    PriusCamper Senior Member
    13,476
    5,443
    Pacific Northwest, USA
    It's nothing you did, it's Toyota's awful design of Gen3 that causes a microscopic leak of coolant where head gasket fails between cylinder #1 and #2 and its intermittent rough running until you get to 200K miles or so when it becomes constant. The main risk when problem becomes constant is a bent rod from too much coolant in the cylinder, as well as transmission dampener that will fail from all that rough running.
  5. Iketorz
    46
    It appears the "it's been very gradually going down for 7 years and 100,000 miles and the car has driven fine basically the entire time" part has been taken as immaterial here. This is the original coolant put in the car from the factory 201,000 miles ago.
    Also: this might not matter but it doesn't have any sign of a blown head gasket whatsoever and head gaskets don't just stop being blown the instant you put it in neutral or give it moderate throttle.
  6. Mendel Leisk
    42,383
    Clogged EGR is the instigator of the head gasket failure. The head gasket’s now breached, coolant’s getting by it, into the cylinder(s).
    the only way to keep 3rd gen EGR operating as designed, is a full cleaning at least every 50k miles. Toyota could have avoided this mess, if they’d tracked tested a few.
    BTW: you might want to check out the British series Hamish Macbeth, a change of pace for your avatar.
    #6 Mendel Leisk, Nov 4, 2025
  7. BiomedO1
    4,641
    2,435
    Left Coast
    LoL, :( Ok, just keeping loading up that parts cannon and ignore all of us and what common sense tells you.
    Think about it. You've automatic dismissed the head gasket issue and won't test to confirm. Your not a dealership mechanic by chance are you?????
    I'm out.....:sleep:
    FWIW; do a litmus test on the coolant, since it appears, that as long as it's wet - It's o'key'doe'key........
    EGR valve could be stuck open; but you claimed to have clean & tested that, which should throw a P0171 along with the rest of the codes. Details matter; so you don't end up chasing your tail........
    #7 BiomedO1, Nov 4, 2025
  8. Iketorz
    46
    But the EGR has never been clogged in the entire time I've owned the car. The two times I cleaned it, I did it proactively and well ahead of time. I did the entire manifold and every single piece in between. The passages were all still flowing quite well at the time.
    To make this clear again: This car has driven just fine with zero issues for all but a cumulative 30 seconds of its entire life in my care, those 30 seconds played out intermittently over the course of this car's 100,000-201,000 miles. Then suddenly it's doing the exact same symptom it's done very rarely since the very first week I've owned the car, except nonstop instead of for a few seconds.
    And again, when I shift the car into neutral, the engine runs perfectly fine. This is not a head gasket, unless you're suggesting this head gasket can be turned on and off at will, instantly by shifting from park to neutral. It goes from shaking like crazy to running like brand new at the pull of a lever.
  9. Iketorz
    46
    Are you ok? I haven't even suggested any of the things you're getting angry at me for doing and you don't appear to have read any of the post I put up.
  10. ASRDogman
    8,070
    4,092
    Since you know everything, why are you here asking for help?
    What does everyone on Prius Chat know about failed head gasket?
    Where's that "ignore" feature???
    PriusCamper likes this.
  11. DirkAshburn
    DirkAshburn Member
    161
    66
    Virginia
    What state of charge does the hybrid battery show when its shaking?
    Brian1954 likes this.
  12. bisco
    52,915
    if it were mine, i'd pull the engine and tranny, and replace that clutchy thingamajig
  13. Iketorz
    46
    I don't know the problem. I know the symptoms; that's why I wrote them down. This is an unusual problem without an easy answer.
    I've put up a few comments and posts related to my car on Priuschat over the years. Every time, starting at probably 120,000 miles, up until now, I have been told by a cumulative dozens of people that the head gasket was blown.
    Meanwhile the car with an apparently blown head gasket has been driving for the better part of a decade getting 40-50mpg doing road trips across the country.
  14. Iketorz
    46
    It's done it in a broad range of charge though this car has only been driven a total of about 5 miles, tops, since the problem started. It sounds so horrific I don't want to do any more damage. I know I haven't let it charge to full during this. The most telling symptom to me is that the problem completely goes away in neutral - when the car isn't charging.
    That's why I'm thinking it's either the clutch connecting the engine to the transmission or it's the EGR doing something that only occurs in certain drive modes.
    The Hybrid Synergy Drive engine management system is a black box of mysterious running modes and I know I've read in the past that the EGR system if it's stuck open or closed when the engine is expecting to have lots of exhaust gas in the combustion chamber, zero exhaust gas in the combustion chamber, or at least to not have a fresh air leak into the combustion chamber, it can really throw the engine off in a hurry because it's already running on the hairy edge of detonation. But that's not necessarily what's happening here.
    There's one reddish orange seal where the metal EGR pipe connects to the intake manifold where I haven't changed it, and if it leaks fresh air in there I wonder if it would be enough to do this but only under charge or drive load when the engine management does (something).
    The reason I'm so reluctant to just jump straight to the clutch or transmission is that this happened with the exact same symptoms, but intermittently, just a few seconds at a time, once every few months, for years.
    #14 Iketorz, Nov 4, 2025
  15. Mendel Leisk
    42,383
    The damper between engine and transaxle often gets damaged, when there's coolant getting into the cylinders.
    So just P0300?
    #15 Mendel Leisk, Nov 4, 2025
  16. PriusCamper
    13,476
    5,443
    If you get a misfire in cylinder 3 & 4 rather than 1 & 2 then you don't have a head gasket but need to replace sparks and coils. That's the only exception I've dealt with. As for where you're at with your car you're in the first stage of grieving for a really expensive car repair. Those of us who been through all the stages of grief on this one and got the work done and got over it aren't going to play along with pretending that Toyota didn't ruin Prius (2010-2015) by changing too many things to make the car unreliable and short lived without major repairs.
  17. Iketorz
    46
    I've been told this almost word for word innumerable times over the years and then I've fixed something simple and driven away.
    This job for me will cost me less than $200 whether it's the head gasket, the clutch springs, or the EGR valve. It's just going to be a pain in the @ss and I want to start in the right place the first time.
    Given the symptoms I can guarantee if I do the head gasket first this car will have the exact same symptoms after I reassemble it.
    #17 Iketorz, Nov 4, 2025
  18. Iketorz
    46
    It did a ton of codes when it first happened but I cleared those out while trying to diagnose while driving in different modes. Right now, it's just the random misfire.
    That damper damage during a coolant leak is certainly interesting. It doesn't explain why this car has made that noise for a few seconds once in a blue moon the entire time we've owned the car before driving away like nothing happened, and only now gone permanent.
  19. PriusCamper
    13,476
    5,443
    Also read up on the high mpg piston rings that was part of the Gen3 design disaster. They have a short lifespan and you'll start losing lots of oil. This was finally corrected in 2014-15 Gen3.
    When it comes time to do the head gasket (sometimes takes years after first symptoms) you'll want to plan to do the piston rings at same time.
  20. rjparker
    rjparker Tu Humilde Sirviente
    11,150
    6,989
    Texas Hill Country
    Not unusual at all. Thousands of gen3s have had your exact symptoms.
    Very common because neutral prevents the erratically misfiring engine from losing sync with the electric motors. Neutral also prevents the engine from charging the hv battery by preventing torque from reaching the electric motors.
    You absolutely have an advanced blown head gasket. The coolant will be lost quickly now and sealer won't help this time.
    A borescope test will show a steam cleaned piston and likely coolant when checked on a cold engine with pressurized coolant.
    The real question is should you risk a hg job alone that may fail or move straight to a replacement engine?
    Detail
    A coolant hydrocarbon check or leakdown test will be negative in the early stages which are past now. Most mechanics believe these common diagnostics are conclusive but they end up being a false negatives.
    Later when its rattling every other day and coolant is down by an inch, the hydrocarbon test "might" be positive. A borescope test is usually definitive by then. At gen3 head gasket end stage with rattling at stop signs and white smoke observable in the rear while revving, most hydrocarbon tests are positive. Rarely will there be coolant in the oil.
    Initially hg leaks are slight, very occasional and don't present like traditional head gasket failures.
    Those early misfires are caused by by minimal leaking of coolantdrops which are quickly sealed as the cylinder heats up. Uneven cylinder cooling design is a contributor. On occasion, a loosened head bolt achieves the same thing, typically after a poor hg repair. Worse case, "waiting" causes a rod to bend and eventually break. Holes in the block can result.
    Overall this is a flawed design that often points to the 2010-14 piston ring flaws which then aggravates a poor egr design. All redesigned by gen4 models. Gen4 also significantly redesigned cylinder coolant geometry and added a cylinder insulator.
