Long Time & Need Your Help!
Discussion in 'Gen 3 Prius Main Forum' started by isipwater12345, Jul 12, 2021.
  1. isipwater12345
    isipwater12345 Junior Member
    Tucson, AZ
    I joined Priuschat in 2012 when I got my Prius and have had zero Prius problems over the last 9 years.
    But this week, when I start the Prius or idle, the battery bars seem to be disappearing faster than usual. Please share your feedback and advice on best next steps.
    I live in Tucson, Arizona and my 2010 Prius has 109,000 miles, I am getting 43mpg. No warning lights have turned on yet.
    I am exploring the following options:
    1) $? - Precision Toyota (local dealer) - new OEM battery, will get quote.
    2) $1,750 - Green Tec Auto in Phoenix - "Brand New Cells" battery with 4 yr warranty + free install
    3) $? - Dan's Toy Shop (Tucson) - new OEM battery, will get quote
    I have considered going with NewPriusBatteries but I don't want to do the install by myself having not done this type of work before. I also don't know of a local independant shop that will install it.
    If I decide to get a new battery, I plan on keeping the Prius for 2-3 more years.
    Thank you in advance!
  2. rjparker
    rjparker Tu Humilde Sirviente
    11,117
    6,975
    Texas Hill Country
    Its good you are looking at the options but you may easily get three years out of the existing battery. No codes and decent mpg, you are ok. Running the AC on high directly discharges the hv battery quick. Normal. The average mpg will drop about four mpg when the battery is weaker. Even if the battery were to code, you can still drive.
    Certainly do not get a used, refurbed, reconditioned and or repainted replacement. Most likely your battery is equal or better than those options. Save a little over the next couple years and buy a new Toyota battery, if you need it, for $1700 - $2250 depending on your market and your ability to shop. Otherwise wait and do the newpriusbatteries thing, paying a local shop to do it. Or, by then the lithium replacement option may have a track record.
    The fact of the matter is, unless it pings when accelerating on a low hv battery the car is doing its job. Pinging would mean excessive carbon buildup under slightly higher load. Carbon is an engine based problem caused by oil burning and resulting blowby. If you are not burning a lot of oil, concentrate on frequent oil changes and maybe an egr cooler cleanup. Not a cheap job to outsource which is why the diy crowd here does it themselves.
    HV batteries do get weaker but weak is not dead. Generate a major maintenance fund but see what the car demands first. A Brake booster, inverter or head gasket could surprise your wallet before the hv battery.
    #2 rjparker, Jul 12, 2021
    isipwater12345 likes this.
  3. ASRDogman
    ASRDogman Senior Member
    8,066
    4,089
    You could get the Prolong charger/discharger that is suppose to revive the battery and make it last longer.
    From the reports I've seen people have said it works and they are satisfied.
    I had originally planned on getting the Prolongs system. But I might just go with new cells from newpriusbatterys.
    Mine has 241+ thousand miles with no problems other than normal wear and tear.
    Installing the harness is something YOU can do yourself. Then it's just plugging it in and letting it run it's course.
    The Prolong system is about 40% the cost of a new battery, and even less if you have to have someone install the battery.
  4. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    what happened to...get the dr prius app to estimate life of hv pack before spending a few grand.
    and probably a bad flywheel.
  5. isipwater12345
    Tucson, AZ
    Thank you rjparker for your feedback. I would love to get another 3 years - b/c otherwise this Prius works perfectly.
    Since the new rapid battery bar drops are new and I am getting a 4-5 mpg drop in the last couple weeks, it is concerning.
    I am at a crossroads.
    • Kbb says private sale = $7,500
    • Got instant sell quote for $5,400 (less money but less hassel)
    • Toyota dealer battery quote = $3,266 (parts and labor)
    • Indepentdant quote (Dan's Toy Shop) = $3,600 (parts and labor)
    • Green Tec Auto "Brand New Cells" + 4 yr warranty = $1,750 (parts and labor)
    The Tucson, AZ OEM and indepdendent prices are much higher than what a lot of others are reproting :(
    Will the battery have a gradual (3 yrs) or sudden (1-3 months) decline? How much time do I have?
    Do I gamble and keep driving and it and hopefull be alright for a couple years?
    Or is it time to sell and move on?
  6. isipwater12345
    Tucson, AZ
    Thank you ASRdogman. I have reviewed the Prolong option and decided it it too much money and time for me. It sounds like a great option for those more technically inclined (unlike me). I would like to go with the newpriusbattties but don't have a local shop for install. But I am wondering what is the difference between newpriusbatteris and greentecauto's brand new cylindrical batteries. I am considering greentecauto since I can drive to their location and get free install. I am not considering used batteries from anyone.
    Thank you Grit. I have not heard of this app, it looks a bit involved priusapp d o t c o m - I am wondering if folks are still using it.
    #6 isipwater12345, Jul 12, 2021
  7. ASRDogman
    8,066
    4,089
    Now you are just being technical!!!! :eek:
    Grit likes this.
  8. PriusCamper
    PriusCamper Senior Member
    13,467
    5,434
    Pacific Northwest, USA
    Finding an honest mechanic to hire to put a brand new pack in is the way to go... If you lived near me I'd charge you 2 hours at $40 an hour to install. The Toyota Stealership on the other hand will charge you for 6 hours at more than $100 an hour even though it only takes them 2 hours to install. #criminals
    New Prius Batteries is just as good as OEM and even better than both of those is this: Toyota hybrid battery upgrade; NexPower Energy
  9. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    pulease, you forgot solid state battery. That’s what I’ll get, lithium will be a thing from the past.
    that happened to me when I left my parking lights on for half a day. When I started up the car, my hv battery went from 60% to mid 40% within 2 minutes. The hv pack was charging the 12v battery. It has happened twice due to low 12v battery, and I get 67 mpg to the tank so hv pack is still good.
    #9 Grit, Jul 12, 2021
  10. ASRDogman
    8,066
    4,089
    My battery has been in service since 24 July 2009, and is still going strong.
    So the new prius battery should last at least half of that, most likely longer, and I'm happy with that.
    The other places, I've not seem very possitive reviews.
    If Toyotat sold only the actually battery pieces, (24 of them), brand new, for close to the $1600, I've buy them.
    I'm antique, I don't imagine I'll be around in another 12 years, so it will be someone elses problem... (y)
  11. isipwater12345
    Tucson, AZ
    Please help me be less technical...:)
    Thank you Priuscamper. I hear you about the Stealership. I was amazed when I found the youtube video where the guy replaces the Prius hybrid battery in 12 minutes. The NexPower batteries look amazing but I am hesitant to do the work myself and don't know of a Tucson shop who will do it. Thank you for your support and insights, much appreciated.
    Amzing you are getting 67mpg! I have a new 12V in my Prius but I have heard that older/worn out 12V's can cause issues.
    #11 isipwater12345, Jul 12, 2021
  12. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    being technical can save a few grand.
  13. rjparker
    11,117
    6,975
    Texas Hill Country
    If you are tired of the car and want something else, sell it. But not because of the hv battery. It won't die quick. Other issues listed earlier can be more significant but you are not really exhibiting symptoms. 109k is relatively low for an eleven year old car. Remember the ac discharges the hv battery faster at idle and long idle with engine restarts quickly reduces mpg. Selling the car now can get you a premium but new car dealers have little to no stock and other used cars are selling at a premium.
  14. PriusCamper
    13,467
    5,434
    If you have a friend who loves to nerd out on Lithium battery stuff... This project will make that person eager to do that work for you... It's the latest in Lithium advancement they'd get to play with.
  15. isipwater12345
    Tucson, AZ
    I am not tired of it, I actually love this car. My fear of keeping it comes from reading too many priuschat threads about sudden hybrid battery failure.
    What are signs of impending and sudden hybrid failure vs. old and slow battery degradation?
    Your perspective helps to decrease my fears, thank you. I hear you about the used car market, this is what I am hearing too.
    PriusCamper likes this.
  16. isipwater12345
    Tucson, AZ
    Wish I did have a friend like that, those lithium batteries look amazing!
  17. TheLastMojojomo
    TheLastMojojomo Active Member
    232
    181
    US
    When you start the vehicle, have you been running the AC right away?
    The Air conditioner compressor will drain the battery quickly.
    It creates is the biggest power draw on the Hybrid Battery, nearly more than doubling all other electronics combined (Headlights, Wipers, etc.).
    The extreme heat of Arizona can cause a Hybrid Battery to degrade faster than it would in other climates. It could be on it's way out but I'd leave your Prius on in READY without the AC, headlights, or wipers on and see if you still experience the same rapid drain first.
  18. rjparker
    11,117
    6,975
    Texas Hill Country
    I think the site has scared you and every little creak may sound like the one thing that will empty your wallet. But you asked so...
    If the brake booster is running every minute or so, thats a $$$ problem that could happen soon or could last a year. The inverter usually has no warning signs and could either leave you stranded or in limp home mode. If the car had the inverter software update recall from years ago, this is less of a concern. A head gasket issue creates an occasional startup rattle that sounds like metal to metal damage in the engine but is actually a leak of coolant into a cylinder that clears in five or ten seconds. This one is a big time warning, $$$ all the way from the head gasket to an engine. Any of these are much more significant and potentially sudden than a hv battery that has yet to throw codes. Each has codes although the head gasket masquerades as misfires misleading owners at first. With all that said, try reducing "idle/waiting" states with the ac on high and don't worry about the above bogeymen just because they sound bad.
    If you were asking about buying this 2010 Prius because you were on a budget, I might recommend a conventional Toyota or Honda. But I assume you own it which makes it an entirely different proposition, one in which is exactly my case. If you could afford a new car and want it, go for it, you get new car safety features and reliability for a price. I bought a new Honda a few years ago and still have my gen3 at 250k miles and original brakes. Speculating about what "might" happen to an older car is almost always going to be wrong.
  19. MelonPrius
    MelonPrius Senior Member
    839
    516
    Nevada
    This raises a good question. Is the consensus that hybrid battery fail is gradual over a period of time with warning signals? Or is it more common that you get surprised with a dead hybrid without warning?
    I often felt that many used Prii are put up for sale because of a weakening or nearly dead hybrid battery. Then the new owner gets a very unpleasant surprise. But that's just my opinion.
    isipwater12345 and Johnny Cakes like this.
  20. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    hang out here long enough you’ll see most new members posting new to me prius with engine knocking.
    #20 Grit, Jul 12, 2021
