Longer oil filter
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Grit, Mar 27, 2018.
  1. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Looking for oil filters that are longer bodied than the stock. At the last meet up, SFO said there are some alternative with longer body because my $4.99 oil filter remover cap kept sliding off even with ribs in the cap groove. Can anymore recommend a few? I'm familiar w/the oil pressure difference, just don't use cheap engine oil and you'll be OK, no worries just do 5K OCIs & save money, if it ain't broke don't it sayings :whistle:
  2. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    If you were to find a longer oil filter you would have to also find a longer oil filter housing. On the GII you could install a longer oil filter, but it's not that easy on the GIII.
    Grit likes this.
  3. Prodigyplace
    12,710
    11,847
    Central Virginia
    I asked my salesman what tool the dealer uses and I bought that, Here is the Amazon link.
  4. Mendel Leisk
    42,242
    I'm using the stamped steel Honda filter socket, it's the same size, nothing fancy, never any problems. I am using a sweet 1/2" wrench (Jet), 1/2" drive swivel head, somewhere around 18" handle length. And it's always been me torquing it, no idiot with an impact driver. This is probably it, mine has an older part number, but looks the same:
  5. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    Bay Stater, Grit and danlatu like this.
  6. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Thanks for the feedback and suggestions, I'll continue to look for a longer bodied oil filter ca/rtridge filter and housing set.
  7. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
