Looked at the Plug-in Prius today (Pictures inside)
Discussion in 'Gen 3 Prius Main Forum' started by muellerfilm, Dec 2, 2009.
  1. drees
    drees Senior Member
    1,782
    247
    Yes.
    Just think of 13-26% on the PHEV as the same target range of 40-80% on the hybrid.
    Remember 13-26% on the PHEV will be about the same battery capacity as 40-80% on the hybrid. So it will function exactly the same as a regular Prius once the battery charge drops to that point.
    No. You will always want to deplete the pack down to the charge sustaining mode. It doesn't matter if you do it the first half or the 2nd half of your long trip, but using it the 1st half guarantees you'll use most of the plug-in energy instead of gas.
  2. gmalis1
    gmalis1 New Member
    134
    Northwest 'burbs, Chicago
  3. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    No.
    I agree with drees.
    The plug-in's concept is trying to drive as long as possible EV range (depletion mode), then it is going to be like a regular hybrid using 13-26% SOC (same capacity as regular 40-80% Prius) called sustaining mode.
    Ken@Japan
  4. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    I think of it like this, after the PHV battery has been depleted 70%, it will "revert" to a standard prius battery, and the ICE charging routine will also revert accordingly to normal hybrid mode.
    But regenerative braking will be able to take the battery to a higher SOC while in normal hybrid mode. Allowing additional depletion mode duration.
    What an advantage that will be!
    Engine efficientcy will not be sacrificed to maintain a higher than normal (necessary) hybrid-mode battery SOC. But regenerative braking can increase SOC back into depletion mode.
  5. Tideland Prius
    16,553
    See... the bold part. I think that's where I was getting confused. I forgot we were working in %s and an Li-Ion battery would obviously have more energy per unit weight than a NiMH battery so that's why I was stuck at 40-80%.
    Ok in that case, then that's fine. That's exactly how I envisioned it would work.
  6. Tideland Prius
    16,553
    See my reply to drees. The bold part was what I was confused.
  7. Tideland Prius
    16,553
  8. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    It is based on following my post.
    The regular Prius has 1.3kWh(0.2kV X 6.5Ah) battery and the usable capacity is 0.52kWh(80-40%:40% of total).
    Assuming the plug-in has 3 times capacity (3.9kWh), the 13.3%(26.6-13.3%) of total is the same 0.52kWh usable capacity.
    Ken@Japan
    2 people like this.
  9. jprates
    jprates https://ecomove.pt
    387
    42
    Moita, Portugal
    2017 Prius PHV
    I can not tell you much more, but I can tell you the capacity is 5 kWh.
    That much as been released to public knowledge already.
    Ken is on the right track... ;)
