LOOKING FOR 2014 PRIUS ENGINE VENDORS
Discussion in 'Gen 3 Prius Technical Discussion' started by Enrico caraig, Jan 29, 2018.
  1. Enrico caraig
    Enrico caraig Junior Member
    Huntington Beach ca
    I need to do an engine swap on my 2014 prius 3. It's throwing a p0301 code due to coolant leaking in cylinder 1. It has 170k miles on it, oil changed religiously and never had issues before this happened.
    i know it's overkill to replace the whole motor for just having a head gasket leak, but this is our daily driver . It has to keep running while i go through and refresh the original motor. any suggestions on where i could get a low mileage engine would be great. BTW, I'm in Orange County California. Thanks!
  2. JC91006
    16,910
    8,632
    Hybridpit in the OC
    RightOnTime and Enrico caraig like this.
  3. makbg1
    makbg1 Junior Member
    35
    LA
    Hi!
    I got mine from here last year. They set it was 30k ml and give you 6months warranty unlimited miles. Mike shire your clutch is in tact when installing the replacement.
    Soken Trade Corporation
    12055 Sherman Way, North Hollywood, CA 91605
    (818) 756-5333
    https://goo.gl/maps/y74ASPsgdhH2
    Enrico caraig likes this.
  4. makbg1
    35
    LA
    Did you find a replacement engine yet?
  5. Enrico caraig
    Huntington Beach ca
    Yes i did.... got a 20k miles from HYBRID 911.
  6. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    How much did the engine costs you?
  7. Enrico caraig
    Huntington Beach ca
    HYBRID 911 charged me $3900 for it. Installed and out the door in 3days. they replaced my a/c compressor as well. Mine was shattered when the connecting rod punched out the block. I personally saw the donor car with the engine still on it, before they took it out and put it on my car. I ran the vin number to get the maintenance history and verified the mileage as well.
    amos, RMB, leeb18c and 2 others like this.
  8. Kuang
    Kuang Member
    37
    38
    US
    Did they clean egr valve, intake manifold .... ?
  9. iskoos
    iskoos Active Member
    415
    254
    Orlando, FL
    I doubt:)
    And if it is really a 20k-mile engine, it probably won't need it...
