Looking for a good digital tire pressure gauge
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Aaron, Mar 31, 2008.
  1. Aaron
    Aaron Member
    260
    Monroe, Ohio
    Looking for a good quality digital tire pressure gauge. Possibly something I can order online. WalMart didn't have anything I was interested in. I did a search on the forums and couldn't come up with anything significant.
    Thanks
  2. Prius 07
    Prius 07 Member
    715
    Toronto, Canada
    I own one of these and it's great. Accurate (shows to one decimal) and provides a very good seal to the tire valve. You can program your desired settings for both the front and back tires. I bought mine a few month ago for $9.99 (when regular price was $35). I see they dropped their regular price to $20.
    Canadian Tire
  3. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    We picked up a good one at Sears. Wasn't that pricey, and works very well.
  4. birdsquared
    birdsquared New Member
    46
    Burnaby, B.C., Canada
    I have the analogue version found here, and am extremely pleased with it, and I am sure the digital version is also high-quality. It's a real boon to be able to add air without having to remove the gauge, and get an instant readout after the filling ends.
    Tire gauges
  5. tochatihu
    tochatihu Senior Member
    9,549
    3,685
    Kunming Yunnan China
    2001 Prius
    While I admire the more-expensive tire gauges, a basic $10 digital served me very well since 2001. I suggest considering these, if only because it could get more people to have (and use!) tire gauges. Very important.
    Peter Blackford in the yahoo toyota Prius group recently reiterated his offer to calibrate pressure gauges for any Prius owners, for the cost of return postage. He is in s. Florida, and hope that he does not mind me mentioning his offer here!
    I don't know what he uses as a standard, but my cheapo gauge tested within a psi way back when. Not all will test that well, but if you know the calibration, that's plenty good enough.
  6. Pinan
    Pinan Member
    173
    Murrieta, CA
    I really like my Tire Minder TMG-340 from Pep Boys. Cost $15:
    Digital Pressure Gauge
    TMG-340-39
    • 2 - 100 psi
    • Saves Gas
    • Red LED Backlight
    • Replaceable Battery
    • Auto Buzzer
    • Auto Off
    See included pic.
  7. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    In another tire pressure gauge thread, 1fixitman had some interesting things to say about gauges, mainly that the accuracy of the digital gauges he tested on a calibrator tended to fluctuate with the temperature of the gauge:
    I would add to his comments that generally it's better to get a gauge with the lowest maximum pressure that would accomodate the highest pressures you will be measuring. E.g., if you will be using the gauge to only measure car tire pressure, then all other things being equal, a gauge that measures between 0-60 psi will be more accurate than one that measures between 0-160 psi.
    Personally, I use the Accu-Gage brand that he mentioned and that Birdsquared also mentioned and linked above. I use one of Accu-Gage's "Professional Series" analogue models that measures 0-60 psi in 1 pound increments, with a release valve and swivel chuck (cost ~ $15).
  8. richard schumacher
    7,664
    1,043
    United States
    Accutire, $7 at Amazon. In a few comparisons with a gas station air pump gauge they always agreed.
  9. partipilo
    partipilo Weirdo
    76
    West Palm Beach FL
    I got a cheapie from Advance Auto Parts, formerly Discount Auto Parts, a year ago, runs on lr44 batteries. blue backlight on the lcd and illumination, works great, probably costed 10 usd.
