Looking for a Skilled Local Gen 2 Prius Mechanic in Syracuse
Discussion in 'Gen 2 Prius Main Forum' started by deekaljin, May 30, 2025.
  1. deekaljin
    deekaljin New Member
    23
    new york
    thanks, brian. the instrument cluster is dark. only the “check engine” light goes on for a bit when i start the car then it goes off. i changed the capacitor last year ..DIY job following youtube videos. and it worked until this happened. however, unlike last time when it was totally dark and nothing shows up, this time it is a little different since the engine light goes on like i said. so i am assuming it is something else since the back up camera doesnt show anymore when i reverse, and the front low beams dont work either (high beams do). i scanned the car with techstream and it threw out these error codes:
    - Error C1241
    - Error C1378
    - Error B1248
    - Error B1271
    i read online that sometimes faulty 12v battery can cause these issues and others, but i put in a new OEM 12v battery just 3 months ago.
    #21 deekaljin, Jun 4, 2025
    51,961
    i can't imagine how the car can start itself without a 12 volt
  3. Tombukt2
    Tombukt2 Senior Member
    12,996
    2,330
    Durham NC
    Yeah that's a pretty good one I have to see that so without without the car would ready you step on gas and engine fires rt up? I no think so .sounds like DC to DC converters intermittent or such . Seems like it's draining 12v or not charging till last minute . With a weak charge system already in place . Bad
  4. deekaljin
    23
    new york
    if it didn’t happen in the dealership, they wouldn’t have believed me either
  5. deekaljin
    23
    new york
    tom, if what you are saying is true, is this car even worth the headache anymore. should i just give up on it?
  6. Tombukt2
    12,996
    2,330
    Durham NC
    Actually if I was correct that's a stupid easy fix I wouldn't dump my car for it unless it was in real poor condition I couldn't use it for a work vehicle or so on the AC don't work etc .
  7. deekaljin
    23
    new york
    what is the easy fix for that?
  8. dolj
    dolj Senior Member
    8,450
    4,291
    Wellington, New Zealand
    The first code implicates a poor 12+ supply to the brake ABS. The other code is saying there is a communications malfunction between the skid control ECU and the brake control power supply assembly.
    The first code is saying that AVC-LAN communication is impossible. The second code is saying the CM has failed (again). The first code might be because of the second code, so fixing the CM would be the first job to tackle if it were me.
    You need to be very wary about what you "read online". Unless you test the battery, you cannot say the battery is good, even if it was replaced three months ago. Even so, I'd be thinking that there might be a problem with 12 V reaching components rather than a problem with the battery.
    Did you or your mechanic actually do any diagnostic testing that is relevant to the codes you found, or are they just loading the parts cannon and hoping for the best?
    #28 dolj, Jun 5, 2025
    Brian1954 likes this.
  9. deekaljin
    23
    new york
    thanks, dolji. i ended up dropping the car at the toyota dealership near me yesterday, and still waiting to hear from them.
  10. Tombukt2
    12,996
    2,330
    Durham NC
    Well that's the last thing you usually want to do but great. The the first thing to do w comm issues . Is physically test said 12V it's AGM in this we looking 12.3 to .7 at rest. Fall much below that . Things get fun. You're seeing faded faint display . Maybe 12V hasn't much behind it.
  11. deekaljin
    23
    new york
    what would be a fix for something like that?
  12. Tombukt2
    12,996
    2,330
    Durham NC
    With a dim display and everything cutting out first thing I'd be doing is load test 12V battery it has to pass period . Until that verified you read thru here it's about 20 to 15 posts we get to oh by the way the 12v fell flat on its face . Replaced like a new car . We're at about 15 or so now I imagine
    deekaljin likes this.
  13. deekaljin
    23
    new york
    update:
    just heard from the Toyota dealership, they “think” it is the CM failure causing all these issues. i am not 100% sure it is really the cause..but will pick up the car tomorrow and do a DIY-job replacing the capacitor again and hopefully that will be the fix.
    #33 deekaljin, Jun 6, 2025
    bisco and Brian1954 like this.
  14. bisco
    51,961
    all the best!
  15. pasadena_commut
    pasadena_commut Senior Member
    2,645
    788
    Southern California
    Maybe it wasn't actually off - it can be hard to tell if the display is out because of the capacitor issue. Also in that state the car often refuses to turn off. If the car is running, even "silently", the 12V can be removed and the inverter will keep 12V going. They then did something to make the gas motor start, or the display kicked in briefly, and miracle of miracles, car starts without 12V. My money is that if they had put a voltmeter across the battery leads while the battery was gone it would have shown around 13.9 volts. They didn't do that because, why would you (normally)?
  16. deekaljin
    23
    new york
    i dont think they tested the 12v battery, pasadena. and to be perfectly honest, i dont think CM failed because if it did, it wouldn’t show “check engine” light goes on. i don’t know why they would say that though.. and i don’t think they really know what’s up with car so they threw that in. it is very frustrating not to have a reliable repair shop around here that can handle these cars.
  17. dolj
    dolj Senior Member
    8,450
    4,291
    I don't know if that is entirely true. Some warning lights can work when the CM has failed.
    Probably because the B1271 means exactly that.
    It may be a different capacitor this time, so maybe it might be worth doing the three main suspects.
    This thread, Combination Meter Repair - DIY, pinned in the Gen 2 Prius Care, Maintenance, and Troubleshooting forum, has all the details.
    Brian1954 and deekaljin like this.
  18. deekaljin
    23
    new york
    thanks, dolji. i will definitely replace the 3 capacitors just in case
    Brian1954 and dolj like this.
  19. deekaljin
    23
    new york
    update:
    i replaced all 3 capacitors and the regulator. but the issue persists.
  20. bisco
    51,961
    maybe get a rebuilt from @Texas Hybrid Batteries
    have you gotten a free load text of the 12v at most auto parts stores?
    another communication issue can be corroded connector pins at the ecu's
