Looking for advice- dead 12v battery-
Discussion in 'Gen 3 Prius Main Forum' started by Vincent Detour, Nov 2, 2019.
  1. Vincent Detour
    Vincent Detour Junior Member
    51
    Toronto, ON
    Well I got the pricier OEM Toyota battery in the end... charged it up and installed seamlessly, thanks to some good Youtube videos.
    Thanks all for the advice and help, I've never done this before, and without the support I might have done what my dealer suggested: "Get it towed to us." Yikes.
    I see that the Motomaster one listed above is also vented, so it might have been fine. But I saved on towing and mechanics charges for doing something that was really pretty straightforward.
    Thanks again. V.
    52,768
    congrats!(y)
  3. BurkPhoto@aol.com
    56
    High Point, North Carolina
    There are many how-to videos on YouTube. It’s easy if you have some metric wrenches and 15 minutes. I’ve done it three times.
    Seven years is a long time on a 12-volt. Mine lasted five each, almost to the month. New Toyota 12V were guaranteed for seven, so you got a fair deal.
    Don’t leave anything on! AGM batteries die soon after they are fully discharged. If you park the car for a week, turn off the Smart Key System if you have one.
    — Bill Burkholder
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Where DOES some of this stuff come from ??
    Fact: An AGM battery is much LESS likely to suffer permanent damage from sitting fully discharged.
    Second fact: A healthy 12 V battery should last a lot longer than a week with NO special considerations.
    Might want to start thinking about it for a month or more.
    Bay Stater and kc5dlo like this.
  5. Siward
    Siward Active Member
    314
    128
    Toronto
  6. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    There’s 4 tires per car so it would make sense that tires on the road out numbers the number of dealerships.
  7. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    227
    Harrisburg, PA
    iPhone ?
  8. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    $191 at my dealer...US ...minus 10% dealer applied discount code.
    Bay Stater likes this.
  9. Toyota lover
    Toyota lover New Member
    Uillinois
