Looking for aerodynamic mod ideas?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by eatdrumss, Feb 24, 2010.
  1. fluxcapacitor3000
    fluxcapacitor3000 New Member
    24
    Socal
    are there any front lips for our cars?
  2. FiveZylinderTurbo
    FiveZylinderTurbo New Member
    Unless you have a computed fluid dynamics program on your computer or a wind tunnel, I doubt you'll improve anything and you might increase lag. Toyota is a big company, Im sure its as aerodynamic as its going to get.
  3. Tekdeus
    Tekdeus Shifted to Green
    151
    Vancouver
    Would a lower custom front air dam reduce drag?
  4. richard schumacher
    7,686
    1,067
    United States
    Could one ever know that it was an improvement without using a windtunnel or industrial-strength CFD?
  5. mainerinexile
    mainerinexile No longer in exile!
    403
    73
    Maine
    Mount a windmill generator in the engine compartment. Not for aerodynamics, but to keep the HV battery charged up and assisting with gas mileage.
    Which reminds me, why not mount short windmills along the interstate to catch the 70mpg wind coming off cars as they whizz by (and regular wind too) and feed the grid? Cheap and easy to maintain.
  6. a_gray_prius
    2,927
    783
    IL
  7. Tekdeus
    151
    Vancouver
    Any idea if such a mod would benefit or mess up the aerodynamics of the Prius with its underbody panels?
  8. a_gray_prius
    2,927
    783
    IL
    In general, people try to reduce the amount of air going under the car as much as possible to reduce drag.
  9. nerfer
    nerfer A young senior member
    2,507
    237
    28
    Chicagoland, IL, USA, Earth
    You should have a good understanding before trying things out, but the Prius is not as efficient as it can be. The EV-1 had a Cd of .19 for instance. Toyota made several compromises so it wouldn't look too outlandish. The original Insight was also more aerodynamic, but looked less mainstream (ironically, people think of the Prius shape & style as somehow 'necessary' for an aerodynamic hybrid).
    Back wheel skirts, better streamlining underneath. If you want to spend the money on cameras instead of rear view mirrors, that's an obvious improvement. I think the front grill (upper & lower) could be improved too, especially if you live in a cooler climate, where a big grill isn't needed. Make it adjustable so you can change the opening based on the temperature.
  10. jeffsf
    jeffsf New Member
    SF, CA
    Sorry if I'm somewhat derailing...but is there a way to mount the front license plate in a more aero position? I've seen some people bend their plates horizontally just before the numbers and use the mounting holes to mount under the front bumper, but was wondering if there's a way to just mount the plate flush with the bumper either on the driver's or passenger's side...
    Edit - okay, I know that it's "illegal" to bend the plate in any way, but Prii's are lowkey anyway, and shouldn't really be targeted...at least here in SF. These cops are either really freakin' busy or really lazy and hang out all the time (like the cops that hang out at my coffee house).
