Looking for basic load-testing of prizmatic cells.
Discussion in 'Gen 2 Prius Main Forum' started by George W, Nov 7, 2019.
  1. George W
    George W Senior Member
    939
    520
    San Antonio
    I switched over my 2008 Touring from OEM cells to Cylinder cells, marketed by NewPriusBatteries . Since the prizmatic batteries are nominal 7.2 Volts, I was curious what the best 'load' would be for the reconditioning process.
    Headlight lamps don't make sense to me, since they are a higher voltage than the source battery. Does anyone think that a 6V 'Lantern' type bulb would make a reliable, steady resistance for a 7 V source? Thank you.
  2. PriusCamper
    PriusCamper Senior Member
    13,467
    5,436
    Pacific Northwest, USA
    Well, these batteries are still so new the reconditioning conversation hasn't really even begun... But in general when I've done reconditioning on Prius batteries 6v is the behavior of the batteries once most of the discharge is done. Even after draining them down to 0.6v they will quickly bounce back into the 6v range. Because of this I thought about buying 6v bulbs for a more thorough discharge, but unlike 12v bulbs, 6v are very rare these days and way, way more expensive than 12v bulbs, which can be found for $2 each.
    Main problem with using bulbs is there resistance isn't fixed and depends on the temperature of the filament. I use them to get the bulk of the charge out of a module, then I use the 10w resister in the charger to do the last bit of it. @Britprius and others say that this method is a good cheat to speed things up, but in general, best results come from a stable discharge of 250ma, which can take an eternity.
    Lastly, the prizmatic batteries are of an identical charge and capacity as standard Prius packs, just configured differently, so I'm not sure why you're saying 7.2v instead of 8.2v?
    NortTexSalv04Prius likes this.
  3. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Your talking about rejuvenating your old batteries to resell they, right?
  4. George W
    939
    520
    San Antonio
    Not necessarily to resell. If I can recondition my old Prius batteries, it raises the possibility of getting another Gen 2 cheap.
  5. George W
    939
    520
    San Antonio
    Sorry, that was a finger-slip. In solar power renewables, a common practice is to use a calibrated shunt in series with the meter to get a highly accurate power measurement. 100mA and 500mA shunts are typical. It sounds like your 10W is the best method for these low voltages. Thank you.
  6. PriusCamper
    13,467
    5,436
    When you say "shunt" is that the same thing as a resistor, just more precise?
  7. George W
    939
    520
    San Antonio
    Yes, in a very specific mppt charging for 12V, 24V, or 48V solar renewables. allows that fixed resistance to track real power in and out of a battery bank.
    PriusCamper likes this.
  8. Skibob
    2,912
    1,505
    Northern California
    Wouldn’t you be better off getting a hobby charger and doing it that way? Then you could match outputs.
    Gen II Prius Individual Battery Module Replacement | PriusChat
  9. George W
    939
    520
    San Antonio
    Maybe, but I don't know enough about hobby chargers. I'm not getting into the business of reconditioning modules, I just want to revive the weak modules from my old pack. If a hobby charger will help me do that then I'd like to know which one has a charge / discharge cycle to accomplish this.
    Quite frankly I'm excited about the prospect. After getting ripped off by a hybrid repair shop to the tune of $2,600, I wouldn't mind finding a second Prius for cheap and putting a good pack in it
  10. Skibob
    2,912
    1,505
    Northern California
  11. PriusCamper
    13,467
    5,436
    When many of us first get started that's a common thought... However, when you replace a bad module in a pack the module you replace it with if you by it from a quality supplier is going to be thoroughly tested, as well as reconditioned. That means the reconditioned module won't match the rest of the pack. I had to learn this the hard way and the hassle of red triangles coming back a day or two after putting the car back together is something you may want to avoid. :)
    As for a hobby charger, I recommend the "HTRC T240" Duo which is the highest quality for the lowest price. It has both DC and AC inputs, so you can plug your solar system into it and fill your battery pack up with sunshine.
  12. PriusCamper
    13,467
    5,436
    That's the hardest part about working on battery packs... Super precise gear that can accurately track and graph power going into and out of the modules is how you can find good, bad and very best modules. Light bulbs, load tests and hobby chargers come no where near that, which is frustrating!
  13. George W
    939
    520
    San Antonio
    Thank you for that recommendation. I would prefer to do all the balancing myself, instead of purchasing one that is pre-reconditioned. I don't mind taking the time. If I'm able to recover the weak modules for use in my next Prius that's a bonus.
    If I can pick up a dead Prius for little money, then maybe I'll buy another cylinder pack from 2K1Toaster. A Gen 2 in good condition with new pack for under 3K, still worth it to me. Again, thank you for that recommendation. Going to do a little price comparison before I purchase.
