Looking for battery booster for 12V
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SweKiwi, Jan 1, 2018.
  1. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    Well....lets see how bad it is in its present state. measure the voltage again with the car off. Write that down. Then turn on the headlights in high beam and measure that voltage. Post them back here.
  2. Sam Spade
    Sam Spade Senior Member
    2,036
    1,024
    2017 Prius c
    If there was only a nominal drain on it when he made that last measurement, he needs to be shopping for a new battery NOW.......because 11.8 with no load is about 70% DISCHARGED. Or 70% dead if you want to look at it that way.
    SweKiwi and Mendel Leisk like this.
  3. SweKiwi
    SweKiwi Junior Member
    16
    Sweden
    Just installed a new battery with the help of a mechanic (~$40).
    Do you other Prius owners have any good personal tips on how to NOT forgot the lights inside in the car?
    I assume this has happened to others. Do you keep them OFF at all times?
    Any tips?
  4. OLA SHOP
    OLA SHOP New Member
    187 Ngõ Quỳnh, Thanh Nhàn, Hai Bà Trưng, TP Hà Nội
    2013 Chevy Volt
    This one you can easy find out on Alibaba from China, have many kind
  5. SweKiwi
    16
    Sweden
    Could you please help me?
    I've never bought anything from Aliexpress :S
    Edit: Would this work for a Prius 2007/2008? I don't want to "blow up" the battery with something too strong or such (I know absolutely nothing about technology here).
  6. bisco
    52,878
    i have left the light on in the past. unfortunately, there is no way to remember, except to remember.
    i try to use it as little as possible, and tell myself to remember when i do.
  7. OLA SHOP
    OLA SHOP New Member
    2013 Chevy Volt
    It cost about 80$, you can do it your self so easy with a Visa card. And the details you can ask directly seller, i''m not in the same country with you, so how can i help you ?
