Looking for How to for Mileage meter over 299K
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ed Martel, May 13, 2022.
  1. Ed Martel
    Ed Martel New Member
    Marylnad
    Hello to all,
    Anyone know a way to fix my odometer so it can read miles again? It stop counting after 299K, about a year ago.
    Thanks
    Ed
    49,430
    call texas hybrid batteries, they might have a way to reset to zero
  3. Peter Stricklin
    Peter Stricklin New Member
    You can swap for the newer cluster, I can't remember the specific year but I believe it is 07-09. Texas Hybrid batteries programmed mine for me with the correct mileage, I did have to disassemble the cluster and swap the right hand section over so the warning lights are correct. Otherwise the wrong lights light up. There is a write up on it that I can't find right now. Maybe someone can chime in with that.
  4. Ed Martel
    Marylnad
    Thank you Bisco, I will give them a call.
  5. Ed Martel
    Marylnad
    Peter, Thanks for the reply, it seems like another option then is to visit a junk yard and look for a newer cluster.
  6. Ed Martel
    Marylnad
  7. dolj
    dolj Senior Member
    7,643
    3,858
    Wellington, New Zealand
    The important thing to note when doing the 07-09 retrofit to an 04-05 is that you need to change both the light cluster and the combination meter. In addition, you need to modify the light cluster to remove the TPMS LED from the 07-09 light cluster as the 04-05 does not have TPMS. If you don't remove it, that LED will always be lit which is apparently very annoying.
    Peter Stricklin likes this.
  8. Tombukt2
    Tombukt2 Senior Member
    9,068
    1,571
    Durham NC
    I cannot imagine having to reverse and go backwards to the 05 to and 6. I have one here that works but I can't imagine putting all that into my 09 that does have TPMS I would be going the other way I'll just drive without the display till I round up one or fails permanently
