Looking for hybrid battery for 2011 Toyota Prius
Discussion in 'Gen 3 Prius Main Forum' started by Gerald10, May 23, 2026.
  1. Gerald10
    Gerald10 Junior Member
    38
    I'm looking for a safe hybrid battery for a 2011 Toyota Prius.
    I’ve read about Nickel-Metal Hydride (NiMH) vs. sodium-ion cell batteries. Do you have any recommendations/experience? Is a sodium-ion cell battery a good option for the Prius?
    Do you have any experience with these hybrid battery options? thehybridgeek or greentecauto
    Hi mudder - saw your youtube video - could you please give some feedback?
    Thanks,
    Gerald
  2. ChapmanF
    19,055
    The one from Toyota has always been safe.
    xw20_driver and Brian1954 like this.
  3. ASRDogman
    ASRDogman Senior Member
    8,070
    4,092
    Sodium Ion is a Great choice. Mine have worked flawlessly
    during heat and humidity and cold.
    Very stable and a great upgrade from the nimh pack.
  4. Brian1954
    Brian1954 Senior Member
    2,694
    1,077
    South Central PA, USA
    I am curious how many miles you have on the car?
    Does it have the original hybrid battery?
    Did you get the P0A80 trouble code?
  5. Gerald10
    38
    I have 167k miles on the car. Yes, I got the P0A80 code. I’m on the second battery (the second battery was replaced by toyota dealership about 4-5 years ago). However, I ran the Dr. Prius lifetime test today and got 56%. I’ll run the Dr. Prius lifetime test a couple more times before I make the decision.
    ASRDogman which Sodium Ion hybrid battery did you get?
    #5 Gerald10, May 23, 2026
  6. Brian1954
    2,694
    1,077
    What you are experiencing is very unusual. I assume the dealership put in a new hybrid battery when they replaced it. These batteries should last at least 10 years. Can you please upload a few Dr Prius screenshots showing the data when you are driving the car during high current (amps) flow into and out of the battery. Do any of the 14 battery blocks ever show as a negative voltage?
    #6 Brian1954, May 23, 2026
  7. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    Alibaba. About $800 delivered. Pick green or orange cells. Nickel metal hydride is a direct replacement
  8. Hayslayer
    Hayslayer Active Member
    539
    331
    Can you please provide PROOF as to why this is an UPGRADE from a new OEM hybrid battery pack?
    Brian1954 likes this.
  9. ASRDogman
    8,070
    4,092
  10. Gerald10
    38
    how can i add a video link here about the dr recording?
  11. Brian1954
    2,694
    1,077
    You need 5 posts before you can add a link. You are now at 4 posts, so make one more, and then you can add the link in your 6th post.
    Did any of the 14 battery blocks show as a negative voltage?
  12. Gerald10
    38
    ok - looks like i need to wait 1 day to post a link lol
  13. Gerald10
    38
    no
  14. Brian1954
    2,694
    1,077
    You should be able to post a link now.
  15. Gerald10
    38
    #15 Gerald10, May 25, 2026
  16. Brian1954
    2,694
    1,077
    I did not see anything unusual in the two videos that you linked, except the resistance of the battery blocks are a little high ( 30 milli-ohms).
    The best information about the battery when the P0A80 code occurs is to look at the freeze frame data for the code. Then you will be able to see why the code was triggered. You need a good scanner to show the freeze frame data for a trouble code.
    #16 Brian1954, May 27, 2026
  17. Gerald10
    38
    Brian1954 but that mean to replace the battery? what good scanner can show that?
    #17 Gerald10, Jun 2, 2026
  18. rjparker
    rjparker Tu Humilde Sirviente
    11,140
    6,985
    Texas Hill Country
    Techstream is able to show freeze frame.
    However I would second Brian's comment questioning how a "new" dealer battery failed in 5 years. Being in Florida your battery may have corrosion which could be diagnosed and fixed for a few hundred dollars. Diagnosing requires inspection and if bad, requires battery removal and likely new bus bars and or wiring. A local independent hybrid shop should be your next move, not buying a sodium for $2k that may not make three years.
  19. ASRDogman
    8,070
    4,092
    If you are just looking for a quick fix, then take it to a place that KNOWS the Prius.
    If you are near Tampa, there is a place there that is very good.
    I'm certain he will check it completely and give you the best solution.
    "IF" you need a hybrid battery, Sodium Ion is your best solution.
  20. Brian1954
    2,694
    1,077
