Looking for others with 12V battery problems for class action lawsuit
Discussion in 'Gen 5 Prius Main Forum' started by Rick B., Jun 4, 2026.
  1. Gokhan
    Gokhan Senior Member
    6,715
    2,672
    Paramount CA
    LOL
  2. fuzzy1
    10,719
    Doesn't a Prius HV-to-12V-bus inverter have a similar capacity?
  3. PriusCamper
    PriusCamper Senior Member
    13,468
    5,438
    Pacific Northwest, USA
    Did you forget to take your meds? You do realize that the problem OP is presenting is not enough charge, not too much charge. Also have you ever tried to get a car owner with a busy life to do more for their car beyond what they usually do? I've been recommending that all Prius do a thorough recharge of their 12v with a legit smart charger that can go up to at least 10 or 20 amps in the darkest parts of winter because the weak sauce amp level won't ever have enough time to for the car to charge it for them and I can't even get people to do that much. And then they call me in Winter because their 12v battery is dead, as if I haven't said anything. And here we are again with an OP wanting to file a lawsuit because that's obviously easier than putting a 12v charger on your 12v every once in a while, right? And then we got you jousting a nonsensical windmill of the dangers of people overcharging their 12v with barely 5amps of charge the Gen5 can produce and claiming that too much 12v idscharge and not enough recharge isn't a substantial design flaw in EVs and Hybrids in the first couple decades. The insanity of it all!!!
    #23 PriusCamper, Jun 5, 2026
  4. PriusCamper
    13,468
    5,438
    It has the ability to do that theoretically, but designers of Hybrids and EVs have chronically underestimated the needs of a 12v battery when it become overly discharged and have opted for a steady low amp charge in the name of efficiency, rather than a variable amp charge in the name of reliability that can quickly recharge a 12v if it's near dead...
  5. Gokhan
    6,715
    2,672
    Paramount CA
    Why is such a simple thing so hard for you to understand? OP’s battery failed because it was already drained when the car was bought. The dealer is required to charge the battery before it is sold, but they didn’t.
    Any car battery will fail if you don’t drive the car, regardless of the make and model year.
    Battery maintenance during predelivery service | National Highway Traffic Safety Administration
    2023p likes this.
  6. PriusCamper
    13,468
    5,438
    Yes but up until the advent of hybrids and EVs in recent decades if you had a dead 12v from lack of use you'd get a jump start and drive the car around for 20minutes and that high amp alternator would put enough charge on your 12v so it worked normall again. With the weak sauce charge the DC to DC inverter provides a 12v in most Hybrids and EVs you're looking at keeping the car on for 12 hours not 20 minutes to get back to a reasonable level of charge. Fortunately Tesla and hybrid vehicle makers are finally getting tired of the complaints and taking steps to address this problem. Of course doesn't seem like Toyota has done a dang thing to deal with this problem yet because they suck at computer code and don't want to invest in getting better at it.
  7. Gokhan
    6,715
    2,672
    Paramount CA
    DC–DC converter, yes. Of course, it does.
    2023p likes this.
  8. Gokhan
    6,715
    2,672
    Paramount CA
    Any battery in any car that is fully drained must be manually charged with a battery maintainer. There will also be a loss of capacity due to sulfation, and the battery maintainer can partially repair it.
    Even the Uplus AGM battery I bought warned in its user manual that the battery must be fully charged before it is installed if the SOC is below about 85% (12.7 V open circuit). Moreover, it says the current limit should be 0.15C (7.5 A for 50 Ah capacity). So, the real world is not that simple that you can put 100 A into a dead battery, and it will be OK afterward.
    You are oversimplifying battery maintenance. You are also thinking that the battery problems in Gen 4/Gen 5 Prius are too common (they are not) and that older cars do not have battery problems (they do).
    2023p and fuzzy1 like this.
  9. fuzzy1
    10,719
    I had understood that my Gen3 Prii (2010 and 2012) had variable rate charging, significantly improved over Gen2, though not to the level you want.
    Did this disappear in Gen4-5?
    Gokhan likes this.
  10. mva
    mva Active Member
    178
    105
    B.C. Canada
    2024 Prius Prime
    SE
    Yes, it can charge at way more than 5 amps! The issue is the logic that backs off the charging to save a little bit of energy and ends up leaving the battery at 50% or less state of charge. And then the car has a significant draw on the 12 volt battery, even when it’s shut off.
    14.3 volts will not destroy the 12 volt battery! After unplugging a similar sensor my Ford F150 alternator charges at 14.3 volts all the time and the battery lasted 6 years.
    Here’s a video with lots of Prius 12 volt system detail including a demonstration of peak charging over 40 amps into the Prius 12 volt battery in “Ready” mode (at the 16 minute mark).
    Gokhan likes this.
  11. Gokhan
    6,715
    2,672
    Paramount CA
    40 A corresponds to a 0.9C charge rate for a 45-Ah battery. That is way higher than what my UPlus AGM battery manual recommends (0.1–0.15C).
    From Google:
    Charging a lead–acid battery too fast forces excess electrical energy to convert into extreme heat and gas instead of chemical potential. This rapid charging leads to internal damage, irreversible capacity loss, deformed lead plates, and a significant risk of explosion due to combustible hydrogen and oxygen gas release.
    2023p likes this.
  12. Gokhan
    6,715
    2,672
    Paramount CA
    Gen 4 and Gen 5 have a 12-V battery management system (BMS) that controls the DC–DC converter voltage using a battery sensor and computer logic. The system is virtually identical in Gen 4 and Gen 5.
    2023p likes this.
  13. mva
    mva Active Member
    178
    105
    B.C. Canada
    2024 Prius Prime
    SE
    Watch the video! At least a minute or two starting at the 16 minute mark. It shows the Prius charging with the battery starting at 12.2 volts.
    The charging peaks over 40 amps for a few seconds and quickly drops down to 20 amps and keeps dropping as the battery state of charge improves. My point is that the Prius DC to DC convertor is quite powerful and in the video it is shown to hold the battery at over 14 volts independently of other heavy draws on the 12 volt system.
    I also noticed that the car can really draw hard on the 12 volt system so it's easy to see how Aux mode can quickly result in a dead battery, especially if starting from 50% state of charge.
    #33 mva, Jun 6, 2026
  14. Gokhan
    6,715
    2,672
    Paramount CA
    Yes, the DC–DC converter can provide over 50 A, I believe. When the 12-V BMS lifts the voltage control on the 12-V battery, as evidenced by the DC–DC converter voltage rising above 14.0 V, there is no current limit on the battery, which could damage it. That is why it is better to use a battery maintainer to recharge a discharged battery than to have the car’s DC–DC converter do so.
    Yes, the car's idle 12-V power drain is quite high, and turning on the 16-W 921 incandescent backup lights in Gen 4 (are Gen 5’s LED?) or using the electric steering increases it even more.
    2023p likes this.
  15. schja01
    schja01 Senior Member
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    I was aware if this issue for years. When I test drove my 2024 in January 2025 they jumped (not charged) the car for the demo. No mention of this to me. When the test drive was over as I was pulling into the parking spot the salesperson said "don't turn off the car" but through habit/muscle memory I pressed the STOP button. They then had to jump the car again to move it back to the sales lot. I explained my understanding of the reason for the dead battery and was met with a "deer in the headlights" look. I insisted on a NEW 12 volt battery or the negotiations would go nowhere. I said make it a AGM battery but Toyota supposidly doesn't sell one of those. It did irk me a bit that they tried to slip a fast one by attempting to sell the car with a damaged 12v. I have a Bluetooth battery voltage monitor and when the signs warrant it I put it on the NOCO Genius at least overninght or longer if possible every month or so. That seems to mask the underlying issue.
    bisco and Gokhan like this.
  16. frodoz737
    frodoz737 Top Wrench
    4,808
    2,562
    33
    FWIW...I bought my ZR1 with a maintainer. Most Corvette folks use them because they don't drive their car regularly. I've never used mine...because I drive the sh-t out of it.
  17. Gokhan
    6,715
    2,672
    Paramount CA
    Yep, that is exactly the problem, which also happened to the OP. Dealers don’t properly maintain the battery and sell it to the new owner with a damaged or drained battery. Any battery that has fully drained must ideally be replaced, as it will be damaged.
    As for a lawsuit, this is not a Toyota issue but a dealer issue. Since the dealer has replaced the battery for free, the OP has no case against the dealer. They should only make sure to drive the car regularly or use a battery maintainer from now on.
    2023p and schja01 like this.
  18. schja01
    1,868
    1,236
    Chicagoland
    2024 Prius
    Limited AWD-e
    This is a design issue. To expect a car owner to babysit the 12v is ridiculous . Not everyone has access to power at their parking location. Older folks may not be able to do it for various reasons. I think a car with this issue should at minimum be able to automatically put itself to sleep with no to minimal power consumption to last several months. My PC can do it so should a car. Just my 2 cents. J
  19. fuzzy1
    10,719
    One of my pre-hybrids had a disclaimer somewhere in the Owner's Manual that it was intended for approximately daily use, not meant to be parked for extended periods.
    2023p likes this.
  20. Gokhan
    6,715
    2,672
    Paramount CA
    I don’t think so. Even my brand-new 2009 Corolla 12-V battery died during the car’s warranty period after I started driving it infrequently and mostly drove my 1985 Corolla. Newer cars will have a greater parasitic drain on the battery. And don’t forget the self-drain, which is large with a flooded cell. No car battery will last if you drive the car only every other week.
    If you only need to drive every other week, consider using Uber or renting a car instead of owning one.
    #40 Gokhan, Jun 8, 2026
    2023p likes this.
