Looking for plug-in charging cable!
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by coltchrist, Jan 19, 2017.
  1. coltchrist
    coltchrist New Member
    San Diego
    I'm looking for a plug-in charging cable. If anyone has an extra that they'd be willing to sell at a reasonable price I'd love to hear from you!
    Pluggo likes this.
  2. Nougatti
    Nougatti Member
    119
    59
    Norway
    FYI, to make your search easier; I believe the one from Nissan Leafs work as well :)
    iPhone ?
    coltchrist likes this.
  3. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    This is a 24 foot 110v charging cable. amazon.com/Electric-Vehicle-Charger-Portable-Charging/dp/B01ERTBKY4
    If you have 220v available and know which plug it is, they are cheaper and faster.
    amazon.com/Portable-Electric-Vehicle-Charger-ReadyCharge/dp/B018A6QK7C
    amazon.com/Portable-Electric-upgraded-expedited-shipping/dp/B01LFW1OK6
    amazon.com/Evmiles-EM-220-16-N14-30-Charger-Level-14-30/dp/B01N0GUQOQ
    Those all use different 220 v plugs, be sure your receptacle matches it.
    coltchrist and jerrymildred like this.
    52,863
    how much are they on ebay?
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    And they cost less, too, I'm told. I toy with the idea of getting a Leaf cable to have at home full time so I only have to drag the cable out of the car at work. Maybe after I've saved enough gas money to pay for it. ;)
  6. bisco
    52,863
    if you're going to make the investment, might be worth looking at L2 cost difference, unless you don't have access to 240v.
  7. jerrymildred
    11,517
    14,167
    Tampa, FL
    Good point. If I had the money available now, I'd be all over this one.
    The other sad part for me is that my panel is full, so no room to add another 240V breaker.
  8. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    The sad part for me is that I have eight 220v outlets in my garage, two of which are three-phase, and no electric vehicles.
  9. jerrymildred
    11,517
    14,167
    Tampa, FL
    That IS sad!!
  10. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    OEM EVSE are way too expensive even used. ~$200. Might as well buy a new L2 EVSE.
    uropip likes this.
  11. bisco
    52,863
    if you can wrangle two 120v outlets from different legs, you can make your own 240v.
  12. mmmodem
    2,732
    1,703
    Bay Area, CA
  13. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Take the washer / dryer CB OUT and replace it with a 50 Amp. Tap 240 volts off the dryer. Also
    That cord is just a cord, you also need the converter box. Juicer supplies box and cord for $499.00
  14. bisco
    52,863
    check out the one for sale by member @zhenya .
    ILuvMyPriusToo and jerrymildred like this.
  15. jerrymildred
    11,517
    14,167
    Tampa, FL
    It's not just a cord. Description, pictures, and all the Q&A make it pretty clear to me that it's a charger. As for upsizing the breaker, I'd most likely also have to upsize the wires. They are probably sized for the 30A breaker that's in there now. In fact, I already found one outlet in the garage that was 20A with a 20A breaker and fed by #14 wire. I fixed that immediately. It's moot to me anyway since I don't have the spare money for it now. What I really should do is replace the whole antique service panel with a Square D. (I'm an electrician, by the way. :cool:)
  16. Andyprius1
    2,327
    859
    Cool CA
    You sound like you know what your talking about then.
    jerrymildred likes this.
  17. bisco
    52,863
    finally! i know where to go for 'lectric advice.:p
  18. jerrymildred
    11,517
    14,167
    Tampa, FL
    Well, I still have a lot to learn about Prii, especially my "new" PiP. But I can find my way around the breaker panel fairly well.
    Just a comment for anyone thinking about putting in a bigger breaker to handle a charger, please be careful that your wires are heavy enough. A 20 A breaker requires #12 wire or larger. Most homes' 15 A breakers only have #14 wire. Putting a 20 A breaker on that circuit is a code violation and a fire hazard. Wire sizes are the same for 20 A whether it's 110V or 220V. For 30 A, use #10. I make it a practice to never use #14. That way, if I ever need to go from a 15 to a 20 A breaker, I don't have to replace the wires. A trick I learned in the factory because engineers tend to use the smallest motors possible and then we'd eventually have to put in a bigger one.
    If you have ANY doubt, have a pro do it. It's way cheaper than a fire.
    Andyprius1 and JimboPalmer like this.
  19. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    I want to repeat this! Even your dryer only runs for 50 minutes, usually while you are awake. Your car is going to charge for 5 hours at 110v, or 2.5 hours at 220v, often while you sleep. The risk of failure is significant. Lets not be in the news.
    Andyprius1 and jerrymildred like this.
  20. Neohippy
    Neohippy Active Member
    220
    201
    Clearwater,Fl
    2013 Prius Plug-in
    I paid $175 for a Leaf charger on eBay.
