looking for some help.
Discussion in 'Gen 2 Prius Technical Discussion' started by HybridFred, Aug 11, 2022.
  1. HybridFred
    HybridFred New Member
    Four Touring
    my wifes pruis has some codes going off curious if i could get some insight into this.
    p1121
    c1241
    c1242
    c1300
    POA60
    B1660
    its 2009 with 168000 miles.. original battery, the 12 volt is newer. looks like some sort of breaking issue. any help with this would be greatly welcomed.
    49,507
    what reader are you using?
    49,507
    p1121 3 way coolant control valve
    c1241 voltage to brake control is low. even a new 12v can be low, or it could be the connector at the brakes, or wiring between.
    c1241-faut-code-abs.208054 see the link in post 8
    c1242 same as above
    c1300 probably related to above
    intermittent-warning-light-dtc-c1300-what-type-of-skid-control-ecu-issue.126202
    p0a60 probably related to above
    codes-p0a60-p0a63-p0a78-poa90-p3000.205856
    b1660 airbag indicator
    watch
    any symptoms, or just trouble lights?
    get a free 12v load test at an auto parts store to start with
    SFO likes this.
  4. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
  5. Boblay
    Boblay Junior Member
