Looking for the correct bolt and screw for 'underside' center motor cover.
Discussion in 'Gen 2 Prius Main Forum' started by George W, Nov 16, 2019.
  1. George W
    George W Senior Member
    939
    520
    San Antonio
    I'm the 3rd owner of a 2008 Touring. The middle plastic-protector that is under the motor is only zip-tied in place(not my doing). I'm getting ready to drive half-way across the country, and was looking to replace it. Since it is held in place with zip ties, I don't have any idea what the correct bolt/screw should be for the new cover. Does anyone know? Thanks.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    I had our 2010’s undercover zip tied for over 150k miles;).
    The rear plastic clip was a bear and wouldn’t come out:cool:.
    So 3 zip ties linked together kept it in place for a long time:).
    I’d just let it be as it is staying in place now and worry about other trip preparations(y).
    SFO likes this.
  3. PriusCamper
    PriusCamper Senior Member
    13,455
    5,430
    Pacific Northwest, USA
    Pretty cool that you even still have a cover... I've yet to be under any Prius that still has the cover you have to remove to change the oil.
  4. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,574
    2,603
    Taylors, SC
    If it has screw threads, it will be a M6x1.0 bolt with a 10mm hex head.
    If it is a plastic push on rivet, it will most likely be 7mm.
  5. George W
    939
    520
    San Antonio
    Thank you. I'm going to run to my closest auto parts and give those a try.
  6. George W
    939
    520
    San Antonio
    I didn't say what condition it is in(terrible). The holes have mostly pulled through and there's a lot of road rash on it. I'm going to be driving 1500 miles in the next couple of days, and I want something under the motor to deflect.
  7. Georgina Rudkus
    3,574
    2,603
    Taylors, SC
    Go to the hardware store to get some "fender washers," to fit where the holes have been enlarged.
    George W likes this.
