Looking for upgraded coils and shocks
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Jose Reyes, Nov 3, 2018.
  1. Jose Reyes
    Jose Reyes Junior Member
    63
    Anaheim
    I'm looking for a upgrade to the coil overs in my 2008 Prius Standard with navigation. Do the touring suspension significantly improve the handling? Anyone have any success with ebay alternatives? After driving a Fiat 500 it makes the gen2 and gen3 a little challenged in the handling department. Car has 110k miles and is otherwise perfect.
  2. a_gray_prius
    2,927
    783
    IL
    I haven't driven a standard suspension model enough to give feedback on whether the touring suspension is a significant upgrade, but I will say that the touring suspension really isn't something I really consider "sporty".
    SFO and Jose Reyes like this.
  3. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    751
    Delaware
    ok I see you have a 2008 too. really, replace the sway bars (and front bushings) with corolla used bars before you do anything else. that will make a huge difference for not much $, and then you can decide if you need to mod it more.
    NortTexSalv04Prius and SFO like this.
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    Are those bolt on’s
    I Have looked at the front link and it looks challenging.
  5. 69shovlhed
    2,170
    751
    Delaware
    the rear is super easy. 2 bolts. the front is a bit difficult; you definitely need to be good with tools, or have a mechanic friend, but it can be done in the driveway with jack stands and a floor jack.
  6. Jose Reyes
    63
    Anaheim
    Just ordered the front sway bar. Needed to replace the catalytic bolts anyway. I was looking at the corolla xrs and wonder if the springs would fit the prius.
