Looking into my first Prius, Higher Mileage a problem?
Discussion in 'Gen 3 Prius Main Forum' started by nate16, Dec 24, 2016.
  1. Lightning Racer
    Lightning Racer Active Member
    239
    321
    Anchorage, Alaska
    My Prius is getting low gas mileage in the winter, as expected. But my old Subaru, which I drive when the conditions are slick, also gets lower gas mileage in the winter, with about the same percentage drop in gas mileage. Summer or winter, the Prius gets two times the gas mileage of the Subaru, so it doesn't matter that it doesn't reach 50 mpg.
  2. nate16
    nate16 Junior Member
    40
    peabody, ma
    Yea I thought about getting another subie but I already blew up one WRX LOL
  3. JC91006
    16,935
    8,645
    for anyone wondering?
  4. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Yep...which is why I said "It's all relative".
    But for a newbie, that may not be familiar with Prius or a Hybrid?
    Well a lot of people just see the EPA sticker and the Toyota advertising....which really doesn't communicate the differences in seasonal and temperature related MPG.
    So my post is just meant as a warning, NOT to expect the upwards of 50 mpg IF the Prius is going to be a "Winter Only" daily driver, in a cold climate with snow tires.
  5. nate16
    40
    peabody, ma
    Yes, I really just wanted to mix it up and try something completely new. I may very well drive the prius many miles during the summer too. I am really enjoying the car so far. Got techstream all up and running too with a j2534, pretty cool. Very similar to BMW's ISPI Next.
    The backlight is dead in my Navi though. I will be making a DIY for doing a screen replacement very soon. Just ordered front brakes too. Wow 88$ for all premium stuff from napa to do both front corners. My M3 is $300 for ONE ROTOR.
  6. Lightning Racer
    239
    321
    Anchorage, Alaska
    What should be said, but never is said is that you'll actually save more money in winter. This is assuming you are driving the same amount in the winter as in the summer, and therefore burning more fuel. The Prius uses half the fuel of my Subaru, and half of a larger amount of fuel use in the winter is a larger amount of savings in the winter.
    For example, lets say you drive the same amount winter and summer, and you spend $50 per month in gas for the Prius in the summer, and $100 per month in gas for something like my Subaru. That's saving $50 per month in gas by driving the Prius in the summer instead of the Subaru. In the winter, the gas mileage might go down 25% in both cars, like from 50 mpg to 37.5 mpg in the Prius and 25 mpg to 18.75 mpg in the Subaru. For the same amount of driving, you'll be spending 1/0.75 or 1-1/3 times more. This works out to $66.67 of gas for the Prius in the winter and $133.33 in gas for the Subaru. That's a savings of $66.67 per month in gas by driving the Prius instead of the Subaru in the winter. So you get a $50 savings in the summer, and $66.67 savings in the winter.
    #46 Lightning Racer, Dec 30, 2016
  7. The Electric Me
    9,083
    5,801
    Not sure you can count on both vehicles efficiency dropping the EXACT same percentage.
    The Prius being a hybrid is built to be on a higher pedestal, with a engine AND a hybrid system.
    But yes, I agree, it's again...all relative and ALL vehicles efficiency drop in colder environments.
  8. Lightning Racer
    239
    321
    Anchorage, Alaska
    In my experience the ballpark drop with temperature is about the same, with my typical driving in a place with snow and ice, and my typical driving with a lot of short trips along with occasional longer trips. Those numbers I used for my example are very close to what I see without doing a scientific comparison. Certainly close enough for me to make the case that I did - that my Prius saves me more gas money in winter than summer compared to my Subaru. You say EXACT. You're not expecting something done to 1% in closeness with that kind of statement are you? What is you experience or expectation? I can't tell from your second to last sentence whether you think hybrids fare better or worse in gas mileage drop relative to non-hybrids in the winter.
    #48 Lightning Racer, Jan 1, 2017
  9. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,804
    1,170
    Auburdale FL
    IMHO I would never buy a car with over 100K on it. But that is just me an nobody else. I trade mine at 100K.
    On a limited budget look at a new base Elantra or base Corolla.
  10. Prodigyplace
    12,710
    11,848
    Central Virginia
    That used to be a good rule to follow. Now I think the mileage should be 150K for most decent cars.
  11. ETP
    2,804
    1,170
    Auburdale FL
    Prius is definitely a decent car.
  12. Prodigyplace
    12,710
    11,848
    Central Virginia
    True, but I would expect the Smart ForTwo isn't (smart). :LOL:
  13. namewish
    namewish New Member
    Missouri
    For the money and what you want to drive I would get a nissan leaf. Why bother with the gasoline at all on such a short commute? Plus you still have a much cooler car for road trips and longer out of town trips.
