Looking to buy a used hybrid battery, need some advice!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by MashinA, Sep 4, 2013.
  1. MashinA
    MashinA Junior Member
    32
    Hey guys so i need to buy a hybrid battery for my 07 prius since mine keeps going bad after spending money on fixing it a couple of times. A friend of mine says he has a battery from a wrecked prius that has around 30k miles on it. My question is what should i look for in a used battery, i know this one has been sitting for several months not being used, is that bad for it? Any other questions i should ask before purchasing? He only wants $350 for it so it seems like a good deal.
    I would appreciate your input as i am pretty new to this. Thanks!
    51,155
    is it from a gen II? it's probably fine, but the only way to be sure, (other than installing it) would be to test each individual cell.
  3. MashinA
    32
    yes its fro ma gen II. As far as testing every cell, how many cells are in there?
  4. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    My advise considering what you say there ,is that if you don't know what you're doing when dealing with 200+ volts of DC battery, is to LEAVE IT ALONE and let someone who is trained deal with it.
    Get it wrong and the battery can kill you.
  5. MashinA
    32
    im not installing it myself....i meant as far as advice on what to look and ask for in a used hybrid battery.
  6. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    That's ok then :)
    I do worry when you see people ask questions about stripping the battery and then add they're not sure what they're doing (there's been many posts in the past). There are many safe guards in the battery but it can still be dangerous.
    Hope you get your car sorted.
  7. Britprius
    Britprius Senior Member
    5,194
    1,918
    Herefordshire England
    The main thing to look or as far as your concerned is obvious external damage dents ect also water damage (stored outside). There is little else that is safe fore a none electrically competent person to do. As GC said this battery has the ability to kill, this is not being alarmist just the truth. The chances are that if this battery was in a working Prius then it will be fine.
    John (Britprius)
  8. Zedhomme
    Zedhomme Member
    227
    68
    Central Florida
    2016 Prius v wagon
    HV Battery Replacement Options
    I have a 2007 Prius Touring with 127,000 miles and no sign of problems with HV battery. There's no exact answer. I suggest visiting Luscious Garage website. They are awesome. Luscious Garage | Blog | Gen 2 Prius HV Battery Replacement P0A80
    They work in California on a lot of Hybrids and especially high mileage Prius taxis. The link is their blog about the HV Battery Pack dependability and replacement options. Read the link long-winded discussion too.
    They have great blogs on many Prius Service issues: Inverter Water Pump, Intermediate Steering Shaft, etc. You may have a free Warranty Replacement you didn't know about.
  9. bisco
    51,155
    i forget, maybe 150 prox.? generally, when a battery goes bad, it's because one or two cells have dropped below tolorence levels. when they are identified, they can be replaced and balanced with the other cells. this is a bit time intensive and some have in the short term) had success just replacing the bad cells with good ones and not bothering to balance them.
  10. sportcoupe
    sportcoupe Junior Member
    44
    There are 28, 7.2v cells in a Prius HV battery pack.
    tai_prius05 likes this.
  11. Britprius
    5,194
    1,918
    There are 168 cells in the battery, these are arranged in groups of 6 that make up a single module. The modules are paired for monitoring by the Prius systems giving 14.4 volts and there are 14 module pairs or 28 individual modules giving an output of 201.6 volts depending on the level of charge.
    John (Britprius)
  12. SteveLee
    SteveLee Active Member
    645
    180
    North Carolina
    I
  13. sportcoupe
    44
    You know what I meant. Call it a module, cell, battery, whatever, there are 28 of them. Each one is 7.2v
  14. SteveLee
    645
    180
    North Carolina
    I
    I think everyone's contribution is appreciated. Using accurate terminology with these more technical aspects I think is important so we can more easily communicate using the same word meanings. Experts here like John and some others are much appreciated. Most of the rest of us are in a learning process about our unique car and benefit from all the input. This group is nearly as great as the car.
  15. Britprius
    5,194
    1,918
    It is important that the correct terminology is used and we are all reading from the same book. If I tell someone to charge the cells to 7.2 volts this could easily be translated into charge the module to 43.2 volts (6 x 7.2), thus destroying that persons module and maybe even causing a fire. The OP asked a question and you gave the wrong information, although I am sure that was not your intention. The OP would not know this information was wrong.
    John (Britprius)
  16. sportcoupe
    44
    Point is if the OP opened up the HV pack he would find 28 batteries inside. That's exactly what he/she was asking. Of course each battery has 6 individual cells in it but they are invisible to the mechanic. I appreciate the correction on the incorrect use of the term "cell".
