Looking to pull the trigger on a 2008 Prius with 255,000 miles
Discussion in 'Gen 2 Prius Main Forum' started by RS4DREW, May 29, 2026.
  1. RS4DREW
    RS4DREW New Member
    Philadelphia
    Hello- my name is Andrew and I’m looking to buy a 2008 Toyota Prius to replace my 2006 Toyota Camry that’s a manual transmission and my arthritic hip can no longer shift gears.
    255,000 miles privately owned second owners last 12 years
    not the prettiest thing in the world, but runs and drive as well as it’s quarks
    am I crazy for doing this buying it for $2000?
    from their ad below
    Within the last year :
    Refurbished hybrid battery
    New car battery
    New injectors
    New coil packs
    New spark plugs
    New hybrid coolant pump
    New tires 5000 miles ago
    255,000 miles
    -Check engine light is on
    -Currently showing a p0304 code
    -does not have a current inspection (it sat for awhile while we were saving up for another hybrid battery)
    Has been a great car for us we just got something newer
    Excellent mileage -we always averaged 43-48mpg or better
    May be an easy fix on the check engine light - we just don’t have the time to look into
    my mother-in-law has a 2007 Prius original 200,000 miles and she loves it. Served her well
    just wondering if I’m making a great decision I drive maybe 5000 miles a year
    I would appreciate your thoughts for a newbie here
  2. PrimalPrius
    PrimalPrius Member
    138
    America
    New injectors
    New coil packs
    New spark plugs
    Possibly because they were trying to fix the p0304 code and weren't successful.
    (I picked up an intermittent misfire as a result of routine maintenance because a new NGK plug from rockauto was internally broken. I doubt that you'd be as "lucky", but it COULD be that one or more of the new parts is bad. Easy to test.
    I was dumb and didn't suspect the reputable new plugs from a reputable source first and swapped coils between cylinders and tested fuel injector pattern with carb cleaner and battery first before going back to the plugs.)
    #2 PrimalPrius, May 30, 2026
    52,820
    welcome!
    while many 2008's are great cars, it is possible that this one could be a major project.
    the refurbished battery alone could be a huge expense.
    I wouldn't get involved with an old hybrid unless I knew the complete history first hand, was hybrid savvy, and had all the tools and skills to keep it running at a reasonable cost.
    there's no comparison between hybrid and gasser maintenance once they're old.
    all the best!
  4. Tombukt2
    Tombukt2 Senior Member
    13,845
    2,515
    Durham NC
    Sounds like this car may have a set of counterfeit plugs you want to sort that out real quick as they've already put new coils and everything else in line
  5. BiomedO1
    BiomedO1 Senior Member
    4,568
    2,399
    Left Coast
    IMHO; if you don't "wrench" you should steer clear. They've already showed you the parts cannon they've already threw at this car without resolution. Your buying someone else's problem child. Just because your mother-in-law has one, doesn't mean that car has received the same meticulous maintenance routine, your mother-in-law has bestowed on her car. Most cars will make it over 200K if routine maintenance is performed at or before OEM specified intervals.
    Food for thought.......o_O:whistle:
  6. frodoz737
    frodoz737 Top Wrench
    4,798
    2,560
    33
    I hesitate to comment because a real mechanic doesn't argue with Google mechanics, but this vehicle has way to many red flags. Do yourself a favor and walk away from this one.
    #6 frodoz737, May 30, 2026
  7. PrimalPrius
    PrimalPrius Member
    138
    America
    Heh, y'all have someone critical of your mechanic skills LOL.
    OP, if you only drive 5000 miles a year, the modest annual fuel savings of a Prius don't make sense considering the lower and more predictable (on average) maintenance costs of a Corolla of similar age and miles. Or a Camry if you want to feel a bit more "upscale" and are willing to pay a bit more for that.
    Your total cost of ownership of a comparable conventional car will likely be lower.
    Your situation is the textbook case for NOT buying an aged hybrid.
