Looks like we're going to need more sunscreen
Discussion in 'Fred's House of Pancakes' started by pilotgrrl, Feb 6, 2018.
  1. pilotgrrl
    pilotgrrl Senior Member
    891
    1,797
    Chicagoan in TX
    A key part of the Earth’s ozone layer is failing to heal — and scientists don’t know why
    I'll start saving up for window tinting...
    http://wapo.st/2E51IZD
    Mendel Leisk and HPrimeAdvanced like this.
  2. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,304
    3,519
    Anaheim, CA
    I see people occasionally walking in our area with umbrellas in full sun; looks like it may become a more common occurrence!
    Is it possible that some of the lower altitude ozone comes from industrial/car pollution which is being reduced due to smog controls?
    What we need is a good sized volcanic eruption!
    #2 HPrimeAdvanced, Feb 6, 2018
  3. Mendel Leisk
    40,584
    VW diesels and their ilk?
    I recently needed to dispose of some used brake cleaner. Looked up for advice, and the best I found was to mix it with some kitty litter in a shallow tray, let it evaporate. Which I did. :oops:
    I think the best bet for the individual, is just try to limit your use, of solvents, in particular aerosol propellant, use water-based paints, that sort of thing.
    #3 Mendel Leisk, Feb 6, 2018
    Zythryn, HPrimeAdvanced and pilotgrrl like this.
  4. pilotgrrl
    891
    1,797
    Chicagoan in TX
    That's really common in Japan, sunscreen is expensive compared to UV-blocking parasols.
    HPrimeAdvanced likes this.
  5. HPrimeAdvanced
    2,304
    3,519
    Anaheim, CA
    The window tint makes a HUGE difference in keeping the car comfortable on sunny days, plus it protects the interior from sun damage, and tends to hide interior contents from would-be thieves.
    pilotgrrl and padroo like this.
  6. Mendel Leisk
    40,584
    Please don't read this as racist, but the only people I see sporting umbrellas in sunny weather around here are oriental ladies. Always. And, it seems a very sensible idea.
    Oh, recall this:
    (from "The Good, the Bad and the Ugly")
    RCO, Prius Maximus and pilotgrrl like this.
  7. Prius Maximus
    Prius Maximus Senior Member
    954
    806
    Northeastern IL
    Love that movie. Recognized the screenshot immediately. I never wore a hat in my younger days. I had a natural hat. Hair. Not any more. I won't carry an umbrella, but I've taken up hats. Not baseball caps. They don't cover the ear or the neck. We need to get back to what worked in the old days. Fedoras. Cowboy hats etc.
    bisco, pilotgrrl, RCO and 1 other person like this.
  8. Mendel Leisk
    40,584
    Sombreros? :whistle:
    bisco and RCO like this.
  9. Prodigyplace
    12,407
    11,682
    Central Virginia
  10. RobH
    RobH Senior Member
    2,374
    987
    70
    Sunnyvale, California
    If you can't use the sun, at least take vitamin D3 as a supplement. A typical blood level of vitamin D is 20 ng/ml (USA units), while an optimal level is at least 60 ng/ml. According to Serum Level vs Intake - GrassrootsHealth , someone with such a level would have to supplement 10,000 IU per day to reach 60 ng/ml.
    Note that vitamin D is only one of several photoproducts of sun exposure. Cholesterol sulfate is another less researched product. Burning is obviously bad, but total avoidance is also a problem.
    RCO likes this.
  11. egg_salad
    egg_salad Active Member
    545
    426
    Las Vegas, NV
    I was under the impression that Prii came with UV-blocking glass.
  12. Prodigyplace
    12,407
    11,682
    Central Virginia
    I think only on 2 ECO and higher trims. It was specifically mentioned as a feature for the 2 ECO.
    Also I have not heard of the Gen 4 windshield breakage issue affecting trim Two. Our trim two already had one situation where we were surprised the windshield did not break.
  13. RCO
    RCO Senior Member
    3,709
    5,185
    Cornwall
    Someplace else, obviously!:unsure:
    Europe banned CFCs as aerosol propellants years ago.
    Seems to be a common thing in tropical far East.
  14. HPrimeAdvanced
    2,304
    3,519
    Anaheim, CA
    I'm pretty sure that glass blocks at least part of the UV radiation; it's infrared that gets through. Tinted glass, depending on the product used, reduces both to varying degrees.
    Note:
    Try using "Sun Hazards and Your Car" in search engine. The link I copied didn't work!
    #14 HPrimeAdvanced, Feb 7, 2018
    RCO likes this.
  15. Trollbait
    12,351
    Plain glass will block a fair amount of UV, and windshields likely block more to reduce UV damage to interior materials. My Transition lenses don't darken in the car or by a window.
    I think you are thinking of IR filtering glass on the Prius. This is what heats up the interior, and reducing it reduces the cooling load for the A/C.
  16. pilotgrrl
    891
    1,797
    Chicagoan in TX
    It gets pretty hot in the summer here
    and whatever's on the windows doesn't do that much. No trees in the parking lot at the job... Perhaps a parasol for the Prius?
    HPrimeAdvanced and RCO like this.
  17. bisco
    51,155
    i just bought a small tube of spf 100, $11.00, :eek: on the lookout for an urban sombrero.:whistle:
    HPrimeAdvanced, RCO and Prodigyplace like this.
  18. davids45
    davids45 Active Member
    104
    132
    Chatswood, NSW
    2016 Prius c
    G'day (from the skin-cancer capital of the world (country, that is)),
    No one has mentioned that UV is a great cause of cataracts (in the lenses of our eyes, nothing to do with rivers and streams).
    So as well as buying better grades of sun-screen cream or lotion, make sure you buy better performance sun-glasses (check the UV-rating, not the design) and wear them if out in the 'midday sun', like those mad dogs and Englishmen noted by Noel Coward.
    If you're in your car, and drive with the windows up (e.g. not hanging an unsleeved arm out a window like maccho-Melanoma-Man), the absorbance of the window glass is good enough to stop the UV (as the owner of the photochromic glasses reported earlier in this thread).
    So no sun-tan and no cataracts through window glass of regular thickness and composition (it's the ferric ion in the glass that is 'our friend' absorbing the UV).
    David S.
  19. srellim234
    srellim234 Senior Member
    1,201
    1,694
    Laughlin, Nevada
    When out and about I've used a Columbia Hat like this for about 10 years. It's been a great one. I picked it up back then on sale at REI.
    Columbia Gravel Watch Cap160 Misc Whiteone - at Stage Stores
    For dirtier jobs like yardwork I picked up a camo Sierra hat that's styled like the Columbia but a little thicker. It's cotton and easy to throw in the washer. That one I picked up for $3 at a thrift shop.
  20. pilotgrrl
    891
    1,797
    Chicagoan in TX
    Not sure about anyone else here, but my optometrist of many years told me that all high-index plastic prescription lenses have UV protection built in.
    He also advised me that almost all lenses are made by the same couple of companies, you don't need to spend more for fancy-schmancy brand names.
