Loose cable near fuse box
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Frozzie, Jul 9, 2017.
  1. Frozzie
    Frozzie Junior Member
    Sydney
    Hi all,
    I was giving a good cleanup to my Prius and decided to open the hood to remove leaves stuck in there.
    Now, I rarely check the engine compartment but while removing the leaves I couldn't help notice a loose cable near the fuse box.
    A couple of months back I left my Prius in a dealership (not my usual mechanic) to have 2 recalls done (fuel valve and airbag). They ended up not doing the airbag as they were missing the part (so much for booking the service ...) ... I'm now wondering if they've left something disconnected.
    As far as I can tell the car is working ok, just wondering what that cable could be ?
    Cheers
  2. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    I'm not sure, but I don't believe we have the same loose cable in our 2011.
    49,492
    sorry, no idea, but you may want to spend more time under there checking the oil before you get a surprise.
    Mendel Leisk and Tande like this.
  4. Tande
    Tande Active Member
    502
    302
    Mich.
    Just checked mine......it plugs into a chassis/mounted connector near the driver/side of the master cylinder brake fluid reservoir .......I have NO idea what it's for......(y)......oops! just realized your "Brake Master Cylinder" is probably on the opposite side of the vehicle from ours, here in the U.S.
    #4 Tande, Jul 9, 2017
  5. ChapmanF
    15,617
  6. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,476
    1,552
    Bay Area
    Looks like a Prius C model. Maybe try posting in their thread forum?
  7. Frozzie
    Sydney
    It's a Prius (no C, no V) ... sounds like I'll have to spend some time checking it a bit further :)
  8. bisco
    49,492
    tande wasn't correct in post #4?
    #8 bisco, Jul 11, 2017
  9. Frozzie
    Sydney
    Not sure if it's because it's a Left Hand drive model but I can't seem to find anything to plug to in that area.
    Search is still on while I raise a complain to the dealership ...
  10. bisco
    49,492
    all the best!(y)
