Loose cable
Discussion in 'Gen 2 Prius Technical Discussion' started by ironduke, Feb 25, 2012.
  1. ironduke
    ironduke Junior Member
    Norway
    Suddenly I discovered a loose cable under my engine :eek: .... Could someone tell me what kind of cable this is?
  2. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    It's a broken one. ;)
    52,695
    ground strap?
  4. Patrick Wong
    18,210
    6,517
    I would be more concerned that there is liquid under the engine. Is that just water from recent rainfall, or is that pink engine coolant?
    That "cable" might be a hose. In any event, it needs immediate attention and if it is a hose, I suggest you have the car towed for service.
  5. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    38
    Santa Fe, NM
    It's not orange (high voltage) so that's good. I'm tearing down a car this weekend so I'll keep an eye out for it.
  6. richard schumacher
    7,682
    1,064
    United States
    [stupid speculation deleted] Since we don't know, best to do as Patrick says and have it towed.
  7. seilerts
    3,326
    1,520
    38
    Santa Fe, NM
    Just had a thought, the engine block heater is the only thing in that area with that much cabling. Is the heater standard in Norway?
  8. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Well it is only about 18 inches long , about... can you get under the car and see where it came from? With its small size there are a limited number of places it could have been ripped out, or dropped out of! As Patrick points out, the puddle of fluid looks bad. The size of the hanging line does indeed look like its supposed to carry fluid!
    If you idle it in the spot it's parked, you should see lights appear on the dash, possibly the RTD!
    Towing it to the dealer really does seem a prudent option!
    Good Luck, let us know what happens!
  9. ironduke
    Norway
    Thanks for all good suggestions... I have a DEFA coupe warmer, and ppl in some Norwegian forum tells me it probably is a cable connected to that. I think the puddle is just water/melted snow. There are no warnings on the dashboard and car runs just fine. No problems.
    2 people like this.
  10. seilerts
    3,326
    1,520
    38
    Santa Fe, NM
    okay, that explains why it looks different from the block heater available in North America. Interesting!
