Loose connection in tail lights?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by RefrigeratedVaporTrap, Jul 12, 2016.
  1. RefrigeratedVaporTrap
    Chicago Suburbs
    2013 Prius c, 59,xxx miles
    I was pulled over the other night for having my tail lights out.
    After investigating the issue in my driveway, it seems that tapping each tail light will make it light back up. Obviously that's not a real solution and they will surely go out again the next time I hit a bump of any kind.
    Has anyone run into this? Any idea the best way to fix it?
  2. Sean Nelson
    Sean Nelson Active Member
    421
    182
    Vancouver, BC Canada
    Step 1: Remove the bulbs, inspect for and clean any corrosion on the contact surfaces and re-insert them, wiggling them around as you insert them into the socket - just in case they're seated improperly.
    Step 2: If that doesn't work, replace the bulbs.
    If that still doesn't work then there may be a common cause such as a wiring issue.
    52,578
    also, check for moisture inside the lenses.
  4. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Intermittent bulbs can be a sign of imminent failure or corrosion. My front parking lights do this. Either way, replacement resolves the issue.
  5. RefrigeratedVaporTrap
    Chicago Suburbs
    Thanks for the replies guys. I'll take a better look sometime in the next few days.
  6. kndy
    kndy Member
    84
    2015 Prius c
    I have had this problem before with my Toyota Corolla at around 68,000 miles and it was around 4 years old. Cop didn't write me a ticket but wanted to let me know that I needed to get it fix. It was pretty the light bulb had to be replaced and it fixed the problem.
    All the best!
