Losing Air in All Tires!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by john_dough, Jul 26, 2009.
  1. john_dough
    john_dough New Member
    75
    Yes, I agree. I subsequently dropped psi to 40/38 and noticed leakage over only a two day period. Today, after reading up on the TPMS, I tightened the nuts which hold them to the rim. Each nut was very lose and I tightened them to what felt like a "reasonable" level. (They require 35 inch pounds, but I don't have a torque wrench)---will now observe over the next few days to see if that solved the problem.
  2. ETP
    ETP 2026/2021 Prime/24 Venza Limit/B52-D,G,F,H
    2,806
    1,170
    Auburdale FL
    Don't you hate it when its your fault. M:Dan that sucks big time.
  3. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    So, just curious. Do the married guys on the forum routinely blame their wives when things fubar? And if so, are they still married?
  4. EZW1
    EZW1 Active Member
    722
    81
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    I try to blame my wife on a lot of things but women have a way of bouncing things right back without logic attached. Kinda reminds me of the child limmerick, "I am rubber, you are glue....."
  5. jayman
    13,439
    641
    Winnipeg Manitoba
    Interesting. I asked as almost every married co-worker/peer I have known, ended up separated/divorced once the Blame Game started
  6. john_dough
    75
    Problem solved---all four tires had loose valve stems, which were tightened, stopping the leak on only three of the tires. One tire also had a small nail in it. The dealer put a plug in the nail hole; this didn't work because the nail was too close to the sidewall. Had to buy a new Integrity tire. All's well at 40/38 psi.
  7. jayman
    13,439
    641
    Winnipeg Manitoba
    Yep, a loose valve stem core will cause a leak. The tool is under $5, and some stem caps actually include the tool in the tip. I always carry such a tool in my vehicle
    My Prius had loose stem cores from the factory, so did my FJ. When I got the winter tires on separate rims for my Prius and my FJ, same damn thing: the tire shop didn't tighten the valve stem core
    What's so hard about that?? Once again, if you don't do it yourself, it doesn't get done right
    Can't do much about a nail. That just happens
