Losing power uphill
Discussion in 'Gen 2 Prius Technical Discussion' started by aprius, Aug 11, 2018.
  1. aprius
    aprius Junior Member
    26
    I
    This just started today. I am losing power when I push the gas all way in. It runs fine unless I need to go up a big hill, which i do regularly. It seems that the trans just stops. I go from mid 70's down to 60mph going up a hill. I get a sound (best way I can explain) when I floor it as if sticking a piece of paper into fan blades.
    Any ideas? Thanks in advance!
    Is the trans going out?
    Minima Domum likes this.
    52,564
    your hybrid battery is probably getting weaker. how many miles on her?
    Raytheeagle likes this.
  3. aprius
    26
    I
    308,000 + :) Been a great car
    DLC82SV, bisco and Raytheeagle like this.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    Pre-ignition issue ? (Detonation?) Uphill's load the engine up. Timing issues/pre-ignition problems typically show up on hills first..
  5. aprius
    26
    I
    So start with plugs and work around?
  6. dolj
    dolj Senior Member
    8,614
    4,373
    Wellington, New Zealand
    If you are getting pre-ignition, or pinking, you should try higher octane gas first. Use 91 (AKI or R+M/2) or higher. If you are often at significant elevation you can use lower than 91 (AKI or R+M/2). What octane rating are you using currently?
    But in all likelihood, the regular mountain work has taken a toll on the HV battery. Be prepared to be replacing it in the near future.
    * AKI or R+M/2 is used in USA.
    #6 dolj, Aug 11, 2018
  7. aprius
    26
    I
    I was thinking I may have some watered down gas as got from a station normally don't. I will run higher octane etc and try. Thanks for info
  8. PAUL SCHULTZ
    PAUL SCHULTZ Member
    103
    66
    Michigan
    How does your air filter look? Also, consider cleaning your MAF sensor. Yes, this could be another HV battery issue but don't forget to consider non-HV battery possibilities.
    Paul
    DLC82SV, aprius and Raytheeagle like this.
  9. aprius
    26
    I
    Changed the filter last week as do every few oil changes and always add Lucas Oil treatment and Lucas Fuel injector cleaner with oil changes.
    DLC82SV likes this.
  10. VFerdman
    VFerdman Senior Member
    1,194
    1,218
    Western Massachusetts
    If there are no codes then it's probably not pre-ignition. At 300+K miles I would definitely look at the plugs, but plugs do not cause problems like this unless they completely fall apart. I would suspect bad gas if this came on suddenly. Consider draining it and refueling with known good stuff.
    Wow! 300+K miles!
  11. padroo
    padroo Senior Member
    2,763
    2,253
    How much oil does it burn, has the catalytic converter ever been changed, i'm thinking plugged exhaust.
    DLC82SV likes this.
  12. aprius
    26
    I
    It is getting a catalytic code now so need to replace that. I am skeptical though to spend that $$ because the battery is still not charging fully and drains very quickly then only charges 50%. The person that hooked it up to scanner said there are no issues with the battery but I find that hard to believe. He also said getting a code for water pump that cools the batteries - could that be preventing it from charging correctly and draining so fast?
  13. padroo
    2,763
    2,253
    The HV battery is air cooled but the inverter has a water pump to cool it.
    Is your inverter resevoir full and can you see movement in the tank?
    aprius likes this.
  14. JC91006
    16,881
    8,620
    So it seems you have an overheating inverter, from a failed inverter pump. That would explain the power loss
  15. aprius
    26
    I
    Reservoir is full and yes and see movement in it. Thx
  16. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,522
    Bay Area, California
    2019 Prius Prime
    How fast does the display cycle between full bars and low bars, starting the engine? What’s your mpg been recently?
  17. joellecool
    joellecool Junior Member
    22
    Washington, DC
    Hello, my car shows similar issues. Some key specs about the car and the situation
    • 2007 Prius, with about 255K Miles
    • Doesn't quickly accelerate without a "rattling" sound when I floor the pedal
    • Loses power uphill, and barely maintains beyond 60MPH
    • Same "rattling" sound when I put on Cruise Control
    • Mentioned it to Dealership mechanic, who suggested Water Pump and Drive Belt, pre-diagnostic. Professional diagnostic would've been more $$
    • Code shows Catalytic converter and misfiring.
    Please help. Thanks !
  18. dolj
    dolj Senior Member
    8,614
    4,373
    How did you get the codes, if you declined the dealer diagnosis?
    There may be other codes the code reader you used cannot see.
    As a WAG, this does sound more like your HV (hybrid vehicle) battery getting very weak. In addition, the misfire could be related to that or could be a separate issue that cleaning the throttle body and MAF may fix. A poorly performing ICE can contribute P0420 (if that the code to which you are alluding).
    If you can get the codes read and get all of them that have been set, we can give more specific advice.
    joellecool likes this.
  19. ChapmanF
    18,757
    I'm not aware of a way for a weak traction battery to cause engine misfiring. Misfires will usually be caused by the usual suspects. Codes about the catalytic converter might reflect the unburned fuel coming out in the exhaust after misfiring, but that unburned fuel can also do real damage to the cat converter, in which case just fixing the misfiring, while necessary, will not make the cat codes go away.
    joellecool and Skibob like this.
  20. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Your cats bad at minimum, possibly old traction battery also. If you need to go to the dealer or any mechanic to fix it you would be better off selling it. The only possible way to break even at this point in your cars life is if you can do the repairs yourself. If you cant then sell it.
