loss of braking while going over bumps???
Discussion in 'Gen 2 Prius Main Forum' started by p123456789, Nov 13, 2011.
  1. p123456789
    p123456789 New Member
    25
    mary esther fl
    Yesterday I was driving the prius when I came to stop for a red light there was a man hole cover that was sunken into the ground fairly deep and when the prius went over it while I was braking I lost braking power for maybe .5 of a second and the traction control light kicked on. This has happend a few times but this time was the worst, is this normal for an 06 prius or should I get it checked out? This NEVER happend in florida we just moved to chattanooga (roads are terrible) the car is also not enjoyable to drive here there are too many tight corners/bumpy roads i'm really thinking about selling it for a larger car that can handle the roads here better. My gti also never does this going over the same bumps/manhole covers. I'd appreciate your advise we have a 7 day old baby and this is our family car so I'm a bit worried.
  2. bluelight_tj
    bluelight_tj New Member
    Houston, TX
    Known issue with the regen braking switching over to physical braking.
    Many other post on this. Try the search.
    I can not post links yet as I am still a noob.
  3. ursle
    ursle Gas miser
    1,049
    192
    NH
    I have an '06 and when I drive from NH to VT in Bellows Falls I cross a bridge with an expansion joint near a stop sign, it's a slight uphill so I'm usually not de-accelerating and I always lose my brakes(after going over the expansion joint) as I start to stop, it's something that just happens, but... it' get's interesting winters when there's snow and ice on the road, losing traction for that 1/2 second may make a difference at some point, sliding out into an intersection would be the result. True it happens at 5mph and below but sliding on ice with no brakes makes for apprehension, IMHO
  4. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
  5. p123456789
    25
    mary esther fl
    This is disappointing I really dont like this "feature" and don't feel safe letting my wife drive around with my newborn in the car you would think they'd have a recall for this. I really like this car but if there is no fix for this it might be time to look at a different car.
  6. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    There was a recall in 2010 where they updated the software to reduce the transition time when transitioning from regen to friction braking in the case of loss of traction. The 2011 already has this "fix".
    You just need to be aware of this issue and allow a little more braking room when light braking over rough or slick surfaces. If my wife was driving around with my newborn I would hope that she was leaving a little extra room in front of her and not following too closely. ;)
    If this still bothers you, maybe you seriously need to look at a different car.
  7. uart
    uart Senior Member
    4,220
    1,212
    Australia
    I also had my Prius for while (about a year) before I noticed this issue. When I'd read people complaining about it I'd often think that they were exaggerating because I hadn't noticed it so bad myself.
    Lately I've been driving on some rougher roads that trigger it, and yeah it can be pretty disconcerting at first. It really feels like your brakes have just suddenly released doesn't it. After some consideration however I think it's more about the "feeling" rather than any really significant increase in stopping distance. It's like that awful feeling that you've just lost your brakes, but I'm sort of used to it now that I know it's only brief and that firmer pedal pressure will overcome it anyway.
    Take your wife over some roads that trigger it and ask her how she feels about it. My wife has never mentioned it to me so I assumed she'd never experienced it, however it turned out (just asked her now) that she had, but it hadn't bothered her too much. I guess she leaves even more stopping distance than me.
  8. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    p123456789: Please update your user info w/your year of Prius. At first I was confused since some folks have cited 3rd gen (2010+) threads and mentioned the recall on the 2010.
    I have an 06 and I'm used the behavior. It's no big deal to me. You can see how I voted at http://priuschat.com/forums/gen-iii...99-poll-prius-brakes-problem.html#post1031776. Please also see Doug's post at http://priuschat.com/forums/prius-h...ius-brake-recall-little-more-information.html, specifically regarding the 2nd gen, which the 06 is.
  9. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Human perception sucks. It is not a problem and only lasts for a few hundred milliseconds. And you still decelerate, just not as fast. There is no increase in speed or lack of braking. It just decelerates less. What you feel is the jerk, or change in acceleration.
    Humans pick that up well. What humans don't do is note the magnitude of the jerk well. Get an accelerometer and you will see it is not a big deal. You need to retrain your senses now that you know what you are looking for. In no way is it unsafe. If you are panic stopping, you are using friction brakes anyways, no issue.
  10. cyclopathic
    3,292
    547
    2014 Prius c
    it becomes more noticeable when tires wear out and grip less.
    yes it is not as bad as long as you don't have a habit of stopping 1' away from car in front.
  11. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    For the OP:
    2k1Toaster has the correct response. The sensation you describe is an artifact of ABS braking. Regenerative braking means that you are more likely to end up in ABS mode. It's not a safety issue: keep braking and everything works just as it should.
    As a minor rebuke: this topic has been addressed hundreds of times on this site. A quick search would have saved time for everyone.
    Tom
  12. uart
    uart Senior Member
    4,220
    1,212
    Australia
    Yep. I'd already read about it so many times before it happened to me, that when it did I knew exactly what was going on and wasn't alarmed. :)
  13. p123456789
    25
    mary esther fl
    You're right I should have searched but I honestly thought there was something seriously wrong with my car and there is no way every prius has a loss of braking going over bumps. The roads here in chattanooga are so bad that you have to slow down to a crawl going over some bumps. I loved this car when I lived in florida it was flat with nice smooth roads but now the I live where there are steep hills bumpy roads and tight corners I've soon figured out that the prius is not suited well for these roads. I guess it might be time to look into another jetta tdi...
  14. El Dobro
    El Dobro A Member
    7,106
    3,282
    I just got out of an '09 Jetta TDI, you don't want to go there. I've gone through the braking thing with the Prius a couple of times and I didn't think it was a big deal. If you keep the pressure on the brake pedal, the car sorts itself out and settles down.
  15. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Physics trumps perception.
    Before you make a malformed sub-optimal decision, go rent an accelerometer if you do not believe the multiple scientists and engineers that have quantified the sensation you "feel" with empirical data that definitively proves it to be a non-issue. It is a physical impossibility for this non-issue to result in any quantifiable reduction in brake capacity.
    Or get a bucket of hot water and cold water, blindfold someone and stick their hand in the buckets randomly. They will fail at identifying which is hot and which is cold. Does this prove that liquids that are hot are not hot? No, it proves that humans are terrible sensors.
  16. p123456789
    25
    mary esther fl
    I'm sorry but this combined with how bad the car handles the roads around here is forcing me to sell it. It has so much body roll around corners and has trouble climbing the steep hills here. The traffic is also bad and it would be nice to have something with some more power for merging.
  17. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Because body roll is an important factor... You drive on the track routinely? Install a sway bar if it bothers you.
    Trouble climbing steep hills? lol. You can't bs me here, I live in the Rocky Mountains ON a mountain. multi-thousand foot elevation drops, 6000ft to 10000ft normal operating conditions up and down and up and down. I-70 has the steepest interstate stretch up the Eisenhower tunnel of anywhere in the country. My little Prius chugs away just fine with traffic up the inclines.
    You are just making up excuses. If you don't want it fine, but that is a personal decision based on really poor judgement.
  18. cyclopathic
    3,292
    547
    2014 Prius c
    hey if you don't like car sell it. Somebody else would be happier with it. It is your loss somebody's find.
    With respect to body roll it is an econo-box not a sports car. You can better it by installing anti-roll bar and strut tower brace if you'd like
  19. qbee42
    18,058
    3,081
    Northern Michigan
    Are you talking about hills in winter, or hills in general? I take my 2006 Prius on rock climbing trips, and I've never had any trouble climbing hills, or mountains for that matter.
    Tom
  20. richard schumacher
    7,683
    1,066
    United States
    I'd just drive slower, but it's your money. Good luck with the PO.., err, I mean, the TDI.
