Loss of Regen Braking?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kevelev, Jun 21, 2019.
  1. kevelev
    kevelev Junior Member
    65
    ny
    So driving to work today the lights went off and all systems returned to normal. Strange...
  2. Mendel Leisk
    41,464
    Have you tried removing that?
  3. kevelev
    65
    ny
    Yes, I removed it right before starting this thread. So it's been a few days.
  4. kevelev
    65
    ny
    Another Update: they came back on just before I got home. Seems intermittent.
  5. CR94
    CR94 Senior Member
    2,694
    1,173
    Northwestern S.C.
    Could be related to battery temperature. Are you monitoring it?
  6. ChapmanF
    18,215
    Same codes? Or just the same warning lights?
  7. kevelev
    65
    ny
    No, I'm not monitoring the battery temp.
  8. kevelev
    65
    ny
    At least the same lights, I will have to recheck later today to see if the codes are the same.
  9. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    This is the que for the “just drive it” motto folks to jump in to save the day.
  10. Mendel Leisk
    41,464
    Ah ok, so that's ruled out.
  11. ChapmanF
    18,215
    The idea of the codes in #16 being related to battery temperature has just left me staring blankly into space, powerless to save any day at all.
  12. Sonic_TH
    Sonic_TH Active Member
    573
    96
    Puerto Rico
    2016 Prius c
    Any updates?
  13. Scott_K
    Scott_K Junior Member
    28
    Central NC
    2014 Prius v wagon
    I love looking up old threads like this describing my EXACT problem and never any update or follow up saying what the fix was....off to the next rabbit hole thread for me!
  14. bisco
    51,950
    you need trouble codes and the service manual
  15. ChapmanF
    18,215
    Did you happen to follow the first page of this thread where it explained the importance of getting your trouble codes and how to do that?
    The service manual is less critical; there are a bunch of us who either have access or have seen at least some of the common trouble codes often enough to remember what they mean.
    This thread doesn't describe your EXACT problem unless you've read your codes and they're exactly the same ones kevelev posted (and not necessarily even then). But either way, once you've said what codes you've got, we can probably help some.
