Loss of SoC while parked in OFF?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by josh2008, Apr 18, 2012.
  1. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    That's probably the SOC% difference between each block. There are 8 battery blocks (each ~25V).
  2. SynEco@eVehicle.co.nz
    139
    Has any one figured out the protocol / data / speed and/or tried monitoring/logging this Serial Link from Battery ECU to HV ECU in GEN III ?? Suspect the battery ECU in the RX400h is also NOT on the main CANbus.
    Maybe this "serial" link is actually just a "private" or "dedictaed" CANbus not visible to the Main CANbus at the OBDII port ??
    Does anyone really know or is it documented any where?
    Paul
